Removing Shift Lever
Old May 12, 2008 | 12:43 PM
2005sporty's Avatar
2005sporty
Stage III
Default Removing Shift Lever
Was wanting to install new shift lever. Just wondered if any one knew how to get the original one off. It's a 2005 Sportster1200 custom.
Old May 12, 2008 | 12:46 PM
DGlide04's Avatar
DGlide04
Default RE: Removing Shift Lever
There should be a small bolt that runs through the lower portion of the shifter that clamps it tight over the splined shaft through the primary. Loosening the bolt should allow you to work the shifter off the shaft, it may have to be wiggled a little to get it to move, but it should slide right off.
Old May 12, 2008 | 01:47 PM
huffhuff's Avatar
huffhuff
you may have to remove the bolt completely for the lever to be removed. there is a depression in the shaft that the bolt goes thru to locate the lever correctly.
OLD 96
May 22, 2021 12:04 PM
apetterez
Apr 20, 2020 04:04 PM
dastark
Jul 14, 2018 12:12 PM
T Man
May 11, 2018 08:07 PM
Carpe Noctum
Dec 3, 2012 07:52 PM
