Replacement Headlight
Old Feb 24, 2006 | 09:07 AM
RandyD123's Avatar
RandyD123
Default Replacement Headlight
I know I saw it in these forums somewhere but I can't find it. I want to replace the stock headlight (just the actual bulb) with one of those SilverStars. I want the bright white...blue doesn't look good.
Is this just a straight bulb swap?
Is it easy to do on a 06 SG?
Do I need to take off the faring?
Is ist just a normal H4 bulb?
Old Feb 24, 2006 | 10:05 AM
DGlide04's Avatar
DGlide04
Default RE: Replacement Headlight
As long as it is a standard H4 bulb, it's a direct swap. Just need to make sure that it is not too high wattage or it may generate too much heat and give you problems you didn't expect. Also, there are other bulbs specifically made for cycles which as we all know vibrate a lot more than a car does. Make sure you get one for a cycle or the vibrations may send it to an early grave.
trappermarc
Apr 16, 2012 11:31 AM
WideBoy04
Apr 18, 2010 12:20 PM
bluedemon06
Apr 13, 2009 05:06 PM
John3:16
Oct 17, 2007 07:34 PM
Beefcake
Jul 22, 2005 04:49 PM
