spark knock
Old May 22, 2008 | 07:41 AM
gene cloninger's Avatar
gene cloninger
Stage I
Default spark knock
have an 02 road king. had big bore 95" installed. screaming eagle heads, 10.5 compression. have a power commander also. use the best fuel i can find, unable to keep from spark knocking even after repeatedly adjusting the power commander, what's next ?
Old May 22, 2008 | 08:06 AM
cHarley's Avatar
cHarley
Default RE: spark knock
Have you checked the MAP sensor? It would help if you better described where the knock is occuring. WOT at upper rpms, lower rpms when going WOT, etc.
Old May 22, 2008 | 08:12 AM
FastHoss's Avatar
FastHoss
I think my spark knock is comming from a bad seal on the rear cylinder valves,spark plugs will tell the story,this one has little globs on the electrode,causing a hot spot,hence the knock.The globs are caused by oil,did not even really notice that it was using any extra,dosen't take much,front plug ok.As soon as motor is warm under a load it starts to knock,even with new plugs.
RidemyEVO
Jul 14, 2015 10:42 PM
Pyrotag
May 3, 2014 03:40 PM
MIKEYGEE101
Feb 25, 2013 09:57 AM
TWIN CAM 96
Mar 7, 2012 01:15 PM
Allan Sheppard
Mar 16, 2010 12:18 PM
