Understanding Spark Plugs
Old Mar 7, 2012 | 12:30 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Default Understanding Spark Plugs
For those of you that don't know how your spark plugs should look take a look at this site.
www.harleyhelp.com/sparkplg.html
Old Mar 7, 2012 | 12:58 PM
mkguitar's Avatar
mkguitar
yes and no. he cites a mixture of facts, rumors and conjecture.
for the novice, and in fact most riders, "reading plugs" is impossible unless there are real mechanical problems with the motor.
modern efi systems and fuel additive packages ( incl ethanol ) make all plugs look "lean" by the standards of the 70's with points ignition systems, centrifugal weight advance, carbs and lead for octane ( the pictures must be from an old manual- they show lead deposits on the plugs)
to get any data from a plug, a new plug has to be installed and the motor run at the rpm and load of interest, then pulled and observed.
...then a new plug for the next rpm range of interest etc.
the part I do agree with is that there are no magic plugs- if a plug alone could increase power or mpg GM, Honda and Ford would love to advertise higher power rating and MPG to meet cafe standards- so they'd use them if they existed.
on a crap old motor an iridium or platinum tipped plug can burn trough soot and deposits.
....and some plugs may not properly work with the ECM activating the anti-knock spark retard and reduced power
mike
Old Mar 7, 2012 | 01:07 PM
old_mikee's Avatar
old_mikee
+1 for what MKGuitar says.... My plugs on my 1700cc carburated Roadstar looked like they just came out of the box, yet the bike was running way rich...
mike
Old Mar 7, 2012 | 01:15 PM
shortride's Avatar
shortride
I think this information is a basic rule of thumb to go by. The conditions of the plugs will give you a good indication that something is not exactly as should be, considering all factors.
jtNIGHTSTER1
Oct 1, 2013 09:05 PM
ib5150
May 29, 2013 11:40 AM
grunt25inf
Sep 18, 2007 02:06 PM
LOU
Apr 26, 2007 10:31 PM
HDF Tech
Engine Mechanical Topics
Jul 2, 2005 03:48 PM
