pulled the plug on the bottom of the motor and a little oil came outmoved the jack and a ltttle more came out.....I cant get the oil to drain out of the tank....filter is off wth not too big of a mess.....what do I need to do....its a 2004 Deuce......thanks
Wrong plug?
Did the plug you pulled out have an allen wrench AND 6 point head. \\; If not you pulled the wrong plug.
Follow the line straight down from the oil tank and you should find another plug.....hopefully
pulled the wrong plu....now I really screwed up.......I was trying to suction the oil out of the tank before I discovered my error and dropped a small piece of 3/8 clear tubing in the tank....how do I oull the tanks...I cant see the tubing...sorry but please help an idiot out!
The oil drain plug is located on the right side of your bike (here is a 'not so great' picture I just took from the User Manual.
If you removed the drain plug from the center of the bike (between the 2 shocks), that is for the transmission fluid.
Pulling the tank (along with all the oil line fittings) is a PITA....
If you have any mechanic friends (gas station, repair shop, etc.) check with them and see if you can borrow some long needle nose type pliers to fish out the tube.
I don't know exactly what they are called, but they have a long, slim type of plier that would reach into the tank and should work.
