Help Cutting down Windshield
Old Jun 8, 2008 | 06:03 PM
Nellybelle's Avatar
Nellybelle
Default Help Cutting down Windshield
I ordered my wife an 17 " Windshield from Drag Specialties.&nbsp\\; OK, I got the wrong one, &nbsp\\;my fault no one elses.
&nbsp\\;
I have already put it on and she says it is OK and she can look through it.&nbsp\\; I was wondering if anyone knows an easy precise way to cut it down an inch or two.&nbsp\\; I thought about takening it to a local window glass company. Or can I do it my self some easy way.
Any thoughts.
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
Old Jun 8, 2008 | 06:12 PM
Kid N8's Avatar
Kid N8
Default RE: Help Cutting down Windshield
Here's what I used from this forum's DIY section:&nbsp\\; https://www.hdforums.com/m_312103/tm.htm
Old Jun 8, 2008 | 06:14 PM
whistler2000's Avatar
whistler2000
It's easy! First draw and cut out a pattern of the windshield on a piece of poster board. Tape up both sides of the windshield with blue masking tape and transfer shape of windshield on masking tape 2" or whatever ya want to remove on the tape using a marker. Cut out shape with sabre saw and finish cut the edge with sandpaper before you remove the tape! Otherwise you will have to deal with many scratches around your windshield, don't ask how I know. Once you're satisfied with the shape, remove the tape.
Old Jun 8, 2008 | 07:47 PM
Other Sheep's Avatar
Other Sheep
That's how I did mine about 3 years ago...Worked real well, used an electric sander with about 400grit paper to smooth the edge.
Old Jun 8, 2008 | 08:58 PM
higlet's Avatar
higlet
I&nbsp\\;have used a 3" angle grinder to cut windshields/lexan, with duct tape on the plastic.&nbsp\\;I find the heat from the cutting disk allows you to break off the edges(?) once they cool. ONCE THEY COOL. Otherwise it burny. Then the sanding
Old Jun 8, 2008 | 09:15 PM
jad's Avatar
jad
ORIGINAL: whistler2000
That's it. I used a band saw as I own one however the saber works good.&nbsp\\;One other tip after sanding to a fine finish you can take lacquer thinner on a rag and slightly melt the edge to give it that factory look. Be CAREFUL and have the windshield top edge down so you don't end up with a big drip down the middle. I've done four and all look good.&nbsp\\;
[IMG]local://upfiles/47469/CA5129376AF541ACB44D2DA128E1853C.jpg[/IMG]
Old Jun 8, 2008 | 09:18 PM
testifer's Avatar
testifer
Took it to the local glass shop, 25 bucks and 10 min wait...looks like a new one
Old Jun 9, 2008 | 06:46 AM
honestbob's Avatar
honestbob
Just make sure you tape it or the saw will scratch it. (don't ask me how I know)
Old Jun 9, 2008 | 09:14 PM
Dc78's Avatar
Dc78
Took mine to glass shop $18.00. Used poster board to make templet of original shape. Marked dropped down&nbsp\\;1 1/2" traced poster board then off to glass shop.
Old Jun 10, 2008 | 10:24 AM
Ronbaci's Avatar
Ronbaci
ORIGINAL: Dc78
Took mine to glass shop $18.00. Used poster board to make templet of original shape. Marked dropped down&nbsp\\;\\\\\\;1 1/2" traced poster board then off to glass shop.
&nbsp\\;
Did you remove all the hardware before taking it done to the glass shop?
Edgeflhtci
Jul 18, 2008 05:21 PM
fonemann
Jun 19, 2008 09:51 PM
fbn ent
Jun 16, 2008 06:54 PM
Im In
Jun 9, 2008 10:29 PM
UCRED
Jun 6, 2008 04:00 PM
