As I understand it, the SERT is no longer being produced/sold by HD. \\;\\\\\\; If you can find one still, the newer SERTs required you to buy the cables. \\;\\\\\\; looking at the part #s you listed, the -08 is a 2008 part #, so would believe this is likely a Pro Tuner,the one you need. \\;\\\\\\; would be worth the check the part # with the dealer before you order to be sure it fits your scoot.
The new SERT is called the "Screamin' Eagle Pro EFI Super Tuner Kit" (part # 32109-08). It retails for $549.95 ($439.96 @ 20% off). You'll also need the cables: "Cable Kit SE Pro Super Tuner", part # 32184-08 for $39.95 ($31.96 @ 20% off). You'll probably have to wait for both of these.
My SERT does not talk to windows vista. It will communicate with XP. I have the new updates but it still conficts. I will solve the problem later. SERT is the only way to go for me.
