Heavy breather install question
Old Jul 17, 2008 | 09:57 PM
wooosaa's Avatar
wooosaa
Default Heavy breather install question
putting a heavy breather on a 04 95 inch screamin eagle&nbsp\\; I will assume as its a SE its a stage one air filter and the breather bolts will not fit properly in the heavy breather&nbsp\\; is it safe to assume the kit was made to go from stock and I will need to buy the stock type breather bolts for the heads&nbsp\\; if anyone knows the part number that would be great&nbsp\\;&nbsp\\; thanks
Old Jul 17, 2008 | 10:01 PM
RjCapp's Avatar
RjCapp
Default RE: Heavy breather install question
The part or kit came with everything I needed. Took the stock completely off. It had all the bolts, breather bolts, gaskets, pre oiled filter etc....Not sure of the part number.
&nbsp\\;
Old Jul 17, 2008 | 10:06 PM
wooosaa's Avatar
wooosaa
hmmmmm i think th only issue is that im putting it on a screamin eagle with the teardrop filter on it from the factory i think that is the diff the breather bolts have a large chrome head on it as opposed to the smaller looking stock ones
Old Jul 17, 2008 | 10:33 PM
PhatHarley4Me's Avatar
PhatHarley4Me
Your going to need the STOCK breather bolts to mount it.&nbsp\\; The SE bolts that you swap out with installing the&nbsp\\;SE air filter are too long.
&nbsp\\;
Cheers
&nbsp\\;
Old Jul 18, 2008 | 01:36 AM
amike's Avatar
amike
ORIGINAL: wooosaa
putting a heavy breather on a 04 95 inch screamin eagle&nbsp\\;\\\\\\; I will assume as its a SE its a stage one air filter and the breather bolts will not fit properly in the heavy breather&nbsp\\;\\\\\\; is it safe to assume the kit was made to go from stock and I will need to buy the stock type breather bolts for the heads&nbsp\\;\\\\\\; if anyone knows the part number that would be great&nbsp\\;\\\\\\;&nbsp\\;\\\\\\; thanks
&nbsp\\;
&nbsp\\;
Part# 29465-99
moose545
Sep 26, 2018 09:44 PM
site351
Feb 6, 2011 10:29 PM
ggibson
Nov 3, 2008 10:51 PM
plysat
Jun 29, 2008 01:57 AM
gussie78
May 20, 2008 07:37 PM
