K&N intake needs breather?
Old Sep 19, 2018 | 10:29 PM
moose545's Avatar
moose545
Default K&N intake needs breather?
Noticed I'm leaking a little oil under my intake location now, few drops. Using everything that came in my kit, pretty sure it had breather bolts too but not sure. Can someone help me find a solution? Share some ideas of what you have setup if possible, thanks
Old Sep 20, 2018 | 12:36 AM
Tall Timber's Avatar
Tall Timber
There are various options for breather kits, start with DK customs.
I ran their intake and breather for about 40,000km. Ended up swapping to a big sucker because I liked the o-rings on the backing plate to breather bolt mounts. Now I just pop the filter off every week or 2 and give it a wipe. There is never enough to drip outside the filter.
Its strange that some bikes puke it out and others drop none.
Old Sep 20, 2018 | 06:29 AM
moose545's Avatar
moose545
Good info, I'll give them a call today and ask some insight to which might be best for the 103"
Old Sep 20, 2018 | 06:35 AM
Iceman24's Avatar
Iceman24
Running DK's intake w/breather kit on my Dyna - love it!
http://www.dkcustomproducts.com/brea...ystems-c21.htm
Old Sep 20, 2018 | 06:36 AM
moose545's Avatar
moose545
I’m running k&n and don’t want to switch it though, so which one should I get? Not trying to get fancy, just functional
Old Sep 20, 2018 | 07:57 AM
joe40x's Avatar
joe40x
The DIY drill and tap kit worked very well on mine.
Old Sep 20, 2018 | 07:59 AM
moose545's Avatar
moose545
Can you post a pic or two, help me understand the reasoning this happens again to begin with.
Old Sep 20, 2018 | 11:52 AM
nevil's Avatar
nevil
I'm a big fan of the DK intake and I did vent the breathers externally, but all you might need to do is pull a little oil out of the motor. Start with half a cup and see if it makes a difference. Where is the oil level reading on the dipstick when hot?
Old Sep 20, 2018 | 12:12 PM
moose545's Avatar
moose545
I ordered the DIY kit and tools, but mine stays at 2 squares from top, hot or cold. Just does don’t ask why, my HD oil cooler jacks that up, at least that’s my conclusion for now
Old Sep 20, 2018 | 09:10 PM
crusader1xxx's Avatar
crusader1xxx
More then likely your a little over filled on the oil...but the biggest reason to go to external breathers is it stops all that crap going through your intake and into the motor....
