K&N intake needs breather?
Old Sep 24, 2018 | 07:21 PM
moose545's Avatar
moose545
Originally Posted by Jonesy82
I’d call DK or K&N to find out for sure. Fingers crossed for you.
I'll give them a call tomorrow and report back, much appreciated
Old Sep 25, 2018 | 10:15 PM
moose545's Avatar
moose545
PSA - the DK Customs breather bolts are only 3/4" long, so that will NOT work with my K&N filtercharger intake and probably not others that are similar. I'm not sure of the hose diameter that comes with the kit but I'm looking to source a brass NPT tee fitting to replace the plastic once that comes with the DIY kit, anyone know what size or type to get, 1/4" or 1/8" all sides?
Old Sep 26, 2018 | 05:20 PM
Rubline's Avatar
Rubline
If you are venting to atmosphere, you might have too much oil in the crankcase. I keep my oil level at half of the dip stick and there are no drips and the misting from the breather bolts is almost nonexistent.
Old Sep 26, 2018 | 05:27 PM
moose545's Avatar
moose545
I’m only using the breather bolts that came with the K&N kit, but my kit arrived today so I will install it and things should calm down I’d imagine. I don’t understand why my levels act how they do but I’ll check it again tonight and keep an eye on it to compare again.
Old Sep 26, 2018 | 09:17 PM
crusader1xxx's Avatar
crusader1xxx
Just make sure you stick to one and only one method of checking....pick either a hot check or a cold check. I have found I get more accurate results doing a cold check.
Old Sep 26, 2018 | 09:44 PM
moose545's Avatar
moose545
Makes sense there, would you say a little high at cold Mark is ok, or too much?
sajor
Apr 2, 2015 05:20 AM
gseely
Sep 24, 2012 07:41 AM
walster
Apr 23, 2012 05:29 PM
gussie78
May 20, 2008 07:37 PM
frook
Oct 19, 2006 12:10 PM
