Tightened trans plug too much
Old Sep 6, 2008 | 10:37 PM
CGLTD's Avatar
CGLTD
Question Tightened trans plug too much
Disclaimer: I tried the search, but didn't find what I was looking for.
I overtightened the trans plug and now it won't tighten down like it should and has a slow drip. I wrapped some teflon tape around the plug and only worked for a while. I used the white tape. Should I use the yellow stuff that's used on gas line connections? Is it possible that I cracked the pan when I over tightened it? How much does the new pan cost? I'm glad that it only hold 24 ounces!
Thanks for the help!
Old Sep 6, 2008 | 10:55 PM
hdpearson13's Avatar
hdpearson13
owe you can go a plus size bigger and should be ok
Old Sep 6, 2008 | 11:00 PM
Chubby's Avatar
Chubby
Ouch!... that's why I always use a torque wrench. Try liquid teflon pipe joint compound made by Permatex... or this http://www.permatex.com/products/mot...ead_repair.htm if that don't work... let us know.
Old Sep 6, 2008 | 11:05 PM
Pacemaker's Avatar
Pacemaker
I would try to put a new drain plug in first. Just might be damage to the threads on the plug and not the pan.
Old Sep 6, 2008 | 11:15 PM
hogdoctor's Avatar
hogdoctor
even with the spec torque, after repeated removal and installs, it can still strip out.. soft aluminum threads.. my best fix is to install a 1/2x20 helicoil thread insert with red locktite, and liquid teflon to cement the plug into place between oil changes...
Old Sep 6, 2008 | 11:30 PM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
+1 right there.
Old Sep 6, 2008 | 11:33 PM
07FXSTC's Avatar
07FXSTC
Did you replace the o-ring?
Old Sep 6, 2008 | 11:34 PM
Chubby's Avatar
Chubby
a helicoil was my next step... but he said that teflon tape worked for a while so I figured it can't be that bad.
Old Sep 6, 2008 | 11:56 PM
Chubby's Avatar
Chubby
WOH! Yes... can't overlook that! Start with the basics first.
Old Sep 7, 2008 | 12:17 AM
GT_RoadGlide's Avatar
GT_RoadGlide
If you felt the metal yield then you probably stripped the pan threads. Helicoil will probably be your next step. When working with threaded aluminum parts using a torque wrench is always a good idea. I buy the HD O ring kit and change all O rings when I do oil changes. I use teflon tape on the plug threads
