Clutch dragging on cold startup
Old Sep 26, 2008 | 10:31 AM
t_waves's Avatar
t_waves
Stage III
Default Clutch dragging on cold startup
I have a 2004 Sportster with 7 k mi. on it. The other day when starting the bike cold while in gear I noticed the bike pulling a little. I put it in neutral and started it, but it did grind a little when I put it in gear. I'm thinking that this could be a simple adjustment, but the mechanic said it could be loose rivets in the clutch plate. Is "loose Rivet" a common problem... Especially on a newer bike with low miles? And can you tell without removing the clutch for inspection? I'm wondering whether or not this guy is just trying to drip into my pocket.
T
Old Sep 26, 2008 | 10:34 AM
RoadKingRon1's Avatar
RoadKingRon1
That has been common on all my bikes. My RK with high compression will wear out a starter when trying to start in gear.
Save the starter and shift to neutral...
ps. you will notice this more on cold starts due to the wet clutch and thicker viscousity.
Old Sep 26, 2008 | 10:38 AM
t_waves's Avatar
t_waves
Stage III
But do you think this is an adjustment or problem with clutch?
Old Sep 26, 2008 | 11:01 AM
RoadKingRon1
No I don't..I think it's normal.
You can adjust the cable for release point and the clutch itself for range of release but I don't know how you could fix this...
On our helicopter we use a block heater to warm up the oil prior to start up......
Old Sep 26, 2008 | 11:07 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
First, before you do anything. Change your oil and adjust your clutch. Cold thick oil will cause clutch drag. Some guys change to a synthetic to reduce this a bit because the syn oils drag less. But my 05 sporty would drag in the Winter and that initial shift into first was always a grinder if I didn't allow the bike to warm up. I went to syn3 which was a bit better. But starting in neutral & allowing the bike to warm up (4-5 minutes) was always best.
If you are adventurous try Redline MT90 in the trans/clutch. It is a 75w90 gear oil with no moly and a thinner pour point than syn3 20w50.
BTW, I doubt there is anything wrong with your bike.
Old Sep 26, 2008 | 01:15 PM
huffhuff's Avatar
huffhuff
i run synthetic ATF in my primary. ATF is obviously formulated for wet clutch discs. adjusting the clutch generally won't change the spring tension holding the discs and plates in the basket. neutral is a good idea. i see many riders backing up their bikes holding the clutch in and getting resistance when they would find it easier if they went to neutral.
Old Sep 26, 2008 | 02:19 PM
Jrsess's Avatar
Jrsess
Try synthetic oil.
Old Sep 26, 2008 | 02:36 PM
t_waves's Avatar
t_waves
Stage III
Default Thanks
From what you all are telling me this is normal. I'm already running synthic oil so before I let this mechanic dip too far into my pocket... I'm just going to make sure the clutch is adjusted properly and see how that works out. Thank you all for your help.
T
REW13
Jun 27, 2019 04:59 PM
NCBANDIT
Mar 11, 2019 04:52 PM
K9BO
Feb 19, 2014 09:53 AM
christo651
Aug 26, 2013 07:47 PM
99octane
Jan 24, 2008 08:03 AM
