How to remove a oil cooler on a 03 Heritage softail
Old Oct 3, 2008 | 09:24 PM
1potter1's Avatar
1potter1
Default How to remove a oil cooler on a 03 Heritage softail
I'm tired of it leaking. I bought the bike with the HD oil cooler on it, so I dont know how to take it off. Is everything just a simple bolt on down to where the orignal area the oil filter mounts too? thanks
Old Oct 3, 2008 | 09:26 PM
Bluesssman's Avatar
Bluesssman
You got it right. Where is your leak?
Old Oct 3, 2008 | 09:42 PM
1potter1's Avatar
1potter1
I dont know for sure. We bought the bike with low miles from the dealer. I could see there was a small oozing oil leak in the cooler adapter area, I had the dealer fix before we bought. They said small hole in one of the lines, they fixed. well the oozing leaks back. So i kinda assume its the adapter gasket leaking because of a new oil filter install(COMMON PROBLEM?). I also dont like how one of the oil line is squezzed under the oil filter, I use syn. and have never needed a cooler in the past.
Old Oct 3, 2008 | 09:57 PM
Bluesssman's Avatar
Bluesssman
Personally I would replace the gasket and keep the cooler... your engine will thank you.
Old Oct 3, 2008 | 10:02 PM
wallyn's Avatar
wallyn
Ditto, Replace the gasket.
Old Oct 3, 2008 | 10:58 PM
JKK's Avatar
JKK
send it to me once you get it off
take it off carefully and pack the hardware with it
Old Oct 4, 2008 | 08:14 PM
1potter1's Avatar
1potter1
Once I remove the oil cooler adapter for the oil filter will I need to purchase the threaded stem the oil filter screws onto to put back to original spec.
Old Oct 4, 2008 | 09:15 PM
bulkman2008's Avatar
bulkman2008
Wish I had an oil cooler on my Heritage .
Old Oct 4, 2008 | 10:38 PM
JKK's Avatar
JKK
nope thats what the adapter screws onto
Old Oct 4, 2008 | 10:45 PM
07FXSTC's Avatar
07FXSTC
Yes - I think I have mine somewhere if you cant get one.....FWIW keep the cooloer though
