Efi idle adjust??
Old Apr 2, 2006 | 11:27 AM
raycer's Avatar
raycer
6th Gear
Default Efi idle adjust??
I want to lower the idle on my 2003 Softail efi. The dealer will not do it for me. They say it will lower the oil pressure...ect. Whatever. I am doing it regardless. I think it idles way to high at 1050 rpm. I want to lower it to 875 or so. Has anyone done this? What is the easiest way? Will a power commander accomplish this?
Thanks
Old Apr 2, 2006 | 12:11 PM
chopperchuck's Avatar
chopperchuck
Default RE: Efi idle adjust??
=either a power commander or a sert will work...the dealer also has a digital tech that will reduce the idle....
Old Apr 2, 2006 | 12:15 PM
raycer's Avatar
raycer
6th Gear
ORIGINAL: chopperchuck
What is a sert?
Old Apr 2, 2006 | 01:29 PM
ICE17N24's Avatar
ICE17N24
screamin eagle race tuner (SERT)
Old Apr 2, 2006 | 01:43 PM
DMSC's Avatar
DMSC
I don't see any way to control idle speed with the Power Commander...at least not on my PCIII USB. Perhaps I missed it...?
I don't know about the SERT...
Old Apr 2, 2006 | 01:48 PM
springer_'s Avatar
springer_
https://www.hdforums.com/m_222256/tm.htm
Check out the thread above. It explains the SERT and covers the Idle adjustment. Personally, I would not lower the idle.
Old Apr 2, 2006 | 02:22 PM
buttman's Avatar
buttman
I agree, the idle speed is set to 1000 RPM for a reason. It wasn't just made up for the hell of it, maybe you should take the advice of a trained mechanic.
[IMG]local://upfiles/8977/FC752F76EB37487C8005953B301E9A96.jpg[/IMG]
Old Apr 2, 2006 | 04:07 PM
raycer's Avatar
raycer
6th Gear
Yes, I agree, and yet I'm still going to lower it. It sounds ridiculous at 1000 rpm with my V&H Big shots. What's worse ist it idles at 1200 when it's cold. Why Harley has to make this so difficult is beyond me. My friend has a carbed bike and it idles at 900 rpm and sounds perfect! I should have bought a carb
[IMG]local://upfiles/10229/F55719B8042D4090A140263A0A5B5A4A.jpg[/IMG]
Old Apr 2, 2006 | 05:16 PM
Shovelhead Bob's Avatar
Shovelhead Bob
With a Fuelie, the ECM controls the cold idle.... 1200 is good.... The ECM can go down to 950 at op temp (260 degrees).
Should you decide that you are going to lower the idle yourself, understand that you will be starving your motor from the very fluid that you are relying on to keep it thumping... Motor Oil...
Plus, without the correct idle, you are preventing the other associated sensors and actuators from working in concert to keep the motor at operating peak.
This is especially true on bikes that have PC's... as they are merely signal thiefs and modifiers of the true sensor/actuator data.
JMPO
Old Apr 2, 2006 | 06:20 PM
PhilM's Avatar
PhilM
There is a reason for the higher idle, but if you really want to lower it, here's how you can.
Remove the air filter and the backplate.
Looking into the throat of the throttle body, on the right side, you will see a small round machined hole that has an convex shaped aluminum insert. It's probably ~1/4" diameter (from memory, which gets worse by the day). If you use a pick or a really small slot blade screw driver, you can pop that convex cover out. Behind it sits the idle screw.
If you have difficulty locating it, once you have the filter & backplate removed, you can look at the throttle linkage (where the cables attach to the throttle body) and see the back side of the idle screw. Use that as a reference to locate the block off plate that "hides" the idle screw.
