fuel pack
Old Nov 2, 2008 | 11:33 AM
ngoti8tor's Avatar
ngoti8tor
If you add just pipes or just a high-flow A/C, you don't need to do anything else.
If you add both the pipes and the high-flow A/C, then you need some type of fuel management.
I chose the V&H Fuelpak since I have a V&H exhaust and I'm not going to do any engine work in the future. If you're going to do any engine work in the future, you should choose a tunable fuel management system.
Old Nov 2, 2008 | 11:43 AM
DMJFatboy's Avatar
DMJFatboy
To get the best performance out of your engine I highly recommend adding a fuel management system fuel pac, pcIII whatever you like. JMO
Old Nov 2, 2008 | 05:12 PM
golfblues's Avatar
golfblues
If your just changing pipes you don't have to do a thing on 08's & up as the ECU will adjust itself but I was told when I put on my Rush 2.0 pipes that if I went for baffles larger then 2.0's I would need a management device. If you add a high flow filter you must add fuel management no mater what. I run aftermarket pipes & high flow air on both of my bikes & they have V&H fuelpaks. I'm very happy with them. Simple install too.
Old Nov 2, 2008 | 05:17 PM
l.ray's Avatar
l.ray
Go search, you will find more info than you can handel, but you will find your answer!
l.ray
Bluesrider.df
Apr 12, 2016 12:24 PM
Dyna346
Jul 26, 2012 07:38 AM
baravettski
May 4, 2009 06:01 PM
harleybiker
Oct 5, 2006 04:18 AM
bull
Jan 20, 2006 07:54 PM
