Im pulling the bagger apart for a bunch of winter work. Alot of paint is missing from the jugs & primary case. What is the best paint to use so it stay's on???
When I bored out my 98 Super Glide I bead blasted the jugs and heads and used a premium high temp engine paint.I cured it in a welding rod oven set on high for a couple of days. It still looked good when I sold it 7 years later
It's expensive, but HD 'sells' their engine paint. I use it on shovelheads and used it on the wheels of my 78 FLH in the pic, when I restored them. I have had good success with it over time.
A tip - when it begins to dull over time, a qwik spray with "Pig Spit" re-brightens it.
J&P also sells an engine paint, but I have not tried it first hand, so not sure if it is the 'same' stuff in a different can or not.
EDIT: As with ANY paint job, the prep is as or is more important than the finish.
You also might try an automotive paint supplier that carries PPG paints. These are the places auto shops buy from. HD uses PPG paints. On my 05 RG they went to PPG to get the correct mix for me.
