header torque?
Old Nov 8, 2008 | 03:31 PM
rickoshay45's Avatar
rickoshay45
Default header torque?
I've been chasing a problem with decel pop and decided to start at the beginning. My HD manual says 100-120 inlbs on the exhaust header studs. That seems a bit low to me. Just wanted to double check
Old Nov 8, 2008 | 03:34 PM
aggro_jo's Avatar
aggro_jo
sounds right. all you are doing is crushing the gasket. remember that they are going to be much tighten when brought up to temp as well
Old Nov 8, 2008 | 03:41 PM
bagman1's Avatar
bagman1
Yep 10 foot pounds is what I remember, sometimes I went a hair more. Just make sure the pipe clamps are loose before you torque the manifold bolts, this is so you are seating the flange in the gasket evenly so its not trying to pull the pipe in too if the clamps were tight. Then after torquing the flange, tork the clamps, then the muffler.
hemi1300
Oct 29, 2014 09:40 AM
rsscoggins
May 28, 2014 05:47 PM
saltlick
May 24, 2014 12:23 PM
rufasim
Apr 21, 2013 03:18 PM
WillieD
Feb 10, 2009 09:18 AM
