Need some tips
The later models, which this is, had incremental improvements and just got better and better. They have a different sound, never matched by the TC's. They are bullet proof and dependable. They are easier and cheaper to work on than are the TC's. For instance, it's a lot cheaper and easier to swap the cam and assuming it's carbed, a lot cheaper to fix than if computerized electronics fail.
Also, it's a lot cheaper to tune a carb for stage one or two than to do injection. The later CV carbs which it should have are all you need.
That later model has electronic ignition which starts and runs better than the early points/condensor models although the earlier ones can be changed.
We have a 96 Wide Glide and it's my favorite ride, above the 02 Deuce and the Heritage.
Imho the Evo will run right with a TC88 because, possibly, the extra drag from the twin cam setup and maybe from the balancer on the softails.
I also believe that the Dynas handle better than the softails, but that's just my opinion.
If you prefer to spend gobs of money and suffer a lot of depreciation, buy a new bike. If you want low total cost of ownership and a reliable fun bike, you can't beat that Evo.
$.02
Look for base gasget leaks and rockerbox leaks. Some rocker boxes can warp and you can never seal them. No big deal you just have to replace them. Those vintage EVOs had some lifter failures in higher mileage bikes. Nothing you can predict but, if your over 20K and the top end is apart I'd replace them.
All in all, they are a good bike, reliable, strong and easy to repair.
This is a really good engine and assuming the bike is otherwise in great shape and the price was right, I'd jump.
You may prefer a good indy for periodic tuning and maintenance - some old salt who's been around. Seems the youngsters at the dealers often don't know how to tune an Evo and they might leave you disappointed for no good reason.
$.02
