Get a metal coat hanger and bend a "S" shape in one end, right below your gas cap is the gauges float sending unit, use a flash light and push down on the float with the ignition on. If theres no change then you probably have a short or an open within the wiring from the gauge to the sending unit.
??? stuck float?? bad sender??? I dont think they are very accurate...on mine it reads empty when i still have 2 1/2 gals left...stealer said that just the way it is.....???? So, i always try to rely on the mileage... sorry i cant help ya....
You can bend the float rod to adjust for the correct gauge reading.
Originally Posted by dad3958
So the float is on the gas fill side?(right) not the guage side.
Thanks
I believe so, thats how my Low Rider is, I would think they would all be the same.
Never had a Harley that had a real accurate gas gauge...I've tinkered with them, but even then, they're hard to get just right...I set the trip odometer when I fill up and go on that...haven't run out of gas once since I first threw a leg over a bike in 1967...
I agree...never relied on one...set the trip and go!
i havnt ran out yet either... but i did forget to turn the petcock on once DOH!!!
