2000 Fat Boy vibration
Old Dec 17, 2008 | 09:46 PM
Dorkman's Avatar
Dorkman
My 2000 Fatboy is smooth as silk. Check the motor mounts. Something is up if you are getting a lot of vibration from an 88b engine. You may also have a death grip on the bars. Try consciously easing you grip and relaxing your elbows. It lets the front end kind of float.
Old Dec 17, 2008 | 10:02 PM
wlvs75's Avatar
wlvs75
I get it when on the highways for a long ride, but I heard if you get some good grips it helps. I just suck it up and shake the blood back into them once in a while. Maybe I should try some ISO grips? Hey Santa if you're on here, you hear that? lol....
Old Dec 19, 2008 | 11:43 AM
bm11027's Avatar
bm11027
6th Gear
Thanks for the input folks. I will go back to the rubber bushings, check the motormount points and get the counterbalance stuff checked I guess.
Old Jul 13, 2010 | 12:19 PM
WhiteKnight2000's Avatar
WhiteKnight2000
I am having the same issue. Handle bars and floor boards vibrate at a certain RPM. Mounts are all tight so I guess ill have to check the balance. Anyone know what the weights are supposed to look like?
Old Jul 13, 2010 | 12:26 PM
spudislandbiker's Avatar
spudislandbiker
Try some bar end weights, do a google search you'll find lots of them out there.
Old Jul 13, 2010 | 12:34 PM
golfblues's Avatar
golfblues
It's not the bushings. I have the polys on both bikes & there is no difference in vibration from the rubber bushings. Don't waste your time & keep the polys, they are better. Finding the real problem would be a better solution.
Old Jul 13, 2010 | 04:19 PM
harleydavis's Avatar
harleydavis
Have you checked the condition of your front tire? If it is worn and cupping you will feel more vibration through the forks and handlebar. My 2000 Fat Boy is smooth as silk and I have 85k on it. I also agree with the ISO grips, as they have made a big difference in hand numbness on long rides.
Smogbob
May 2, 2022 01:34 PM
vern58
Sep 30, 2021 09:45 PM
TexasBikeBoy
Jan 23, 2010 05:37 AM
6 gun
Nov 19, 2008 03:03 PM
Ben Sundey
May 2, 2008 10:58 PM
