Newbie ?
Old Apr 11, 2006 | 02:22 PM
alabama1's Avatar
alabama1
Default Newbie ?
Hay guys i have seen a lot of talk here about getting a SERT, as i am a new rider can someone tell me what that is? Thanks
Old Apr 11, 2006 | 02:33 PM
mutha's Avatar
mutha
Default RE: Newbie ?
Screamin Eagle Race Tuner
Old Apr 11, 2006 | 02:47 PM
ricoman's Avatar
ricoman
go into the Tech Tips and DIY section and prowl around - there is more info on SERTS than you may even want to know.
Old Apr 11, 2006 | 04:53 PM
FireHawk's Avatar
FireHawk
The Screaming Eagle Race Tuner allows direct access to the ECU programs and their modification. We are, in affect, creating custom calibrations for specific combinations (just like H-D reflash cartridges). The Race Tuner does, however include many SE calibrations in the map files to select from. These can then be modified or a completely new file created if the combination does not match the calibrations part description.
Race Tuner provides a much higher level of tuning than any other device without replacing the ECU itself. Each cylinders fuel and ignition mapping is independently tuned, using three dimensions, resulting in a custom map that eliminates the possibility of one cylinder fighting or holding back the other.
This equals more horsepower with smooth linear drivability. In addition, warm up enrichment, idle speeds, IAC steps, rev limits, AFR offsets, injector sizing can be changed. To help in tuning or diagnostics, Race Tuner also features a data mode to collect and review sensor inputs or other data. Both of these can only be tuned accurately by using a Computer controlled load cell dyno with real time AFR monitoring.
I found that information at this site
chuck2000RK
Jun 18, 2008 09:28 PM
rangergord
Apr 11, 2008 04:52 AM
grimreaper169
Jan 2, 2008 09:03 AM
fiddledicksr
Exhaust System Topics
Nov 7, 2006 01:35 AM
brianseay
Jan 30, 2006 03:55 PM
