EFI to Carb Conversion
Old Jan 2, 2009 | 01:24 PM
Medicfrost's Avatar
Medicfrost
Default EFI to Carb Conversion
I'm having more and more problems with my aging EFI system, and am considering converting it to a Mikuni 45mm Carb. If anyone reading this post has ever done it, did it work out well for you? I found a site that lists the procedure, and it doesn't look too complex.
http://www.amm.haan.de/Carb/carb.htm
Old Jan 2, 2009 | 03:14 PM
ackman1968's Avatar
ackman1968
There was a thread on this in the Dyna forum. Maybe some help to you.
https://www.hdforums.com/forum/dyna-...onversion.html
Old Jan 2, 2009 | 03:16 PM
MATUCHI's Avatar
MATUCHI
A coworker made that change on his bike and hasn't had any problems with it. I would think the EFI system would be a plus on a motorcycle?
Old Jan 2, 2009 | 03:30 PM
hpfatboy's Avatar
hpfatboy
Talking
Can be converted quite easily according to some guys on this site, who have done it. I LOVE THE CARB., CHOSE it over fuel injection. CARBS have been around for ever, and seemed to have worked fine, until all this new technology came along. What did they use before FUEL INJECTION? Plus if theres a problem with your CARB, you can work on it your self on the side of the rode. Can you do that with fuel injection? NO, its off to the shop. Give me a CARB. ANY DAY. GOOD LUCK!
Old Jan 2, 2009 | 03:57 PM
Medicfrost's Avatar
Medicfrost
It was a plus, but mine had frequent problems with sensor failure since I've owned her, which may be because of it being among the earliest DELPHI EFI systems released. I saw that AMERICAN BAGGER has the procedure illustrated out in their Dec 08 and Jan 09 issues, which should be pretty helpful.
Old Jan 2, 2009 | 04:41 PM
JKK's Avatar
JKK
since the EFI models have a fuel pump and vaccum shut off, youll need to pet your ****
so it dont leak...
Old Jan 2, 2009 | 04:57 PM
Airpump's Avatar
Airpump
so it dont leak...
WHAT
Old Jan 2, 2009 | 04:59 PM
JKK's Avatar
JKK
Smile
Originally Posted by Airpump
WHAT
he'll need a petcock says I...
Old Jan 2, 2009 | 05:01 PM
Medicfrost's Avatar
Medicfrost
Ohhhhh, I was petting it all afternoon, and it has leaked quite a bit.
Old Jan 2, 2009 | 05:03 PM
PastorTom's Avatar
PastorTom
Never actually done it, but I do run a part time labor free Indy shop and have been askd more then once about it..
Thanks!
PT
