Melted microfiber on chrome
Old Apr 27, 2010 | 01:36 PM
  #31
spiralmind's Avatar
spiralmind
Stage I
Default microfibre welded to hot chromium
Hi all, new member, with some good advice on the above. History. Collect brand new bike on Friday, pride and joy, ride it home. Weather shitty so wait till Saturday for a cruise, brilliant, big smile all over face. Back home, park bike in garage. Pick up microfibre cloth for a last clean before drinktime. Cloth falls from hand, hits hot exhaust and immediately welds to chrome. HORROR, ONE DAY OLD AND SCARRED FOR LIFE!
Not so my friend. Get 100 per cent cotton cloth and good quality chrome cleaner and put on standby. Start engine and run for 15 - 20 minutes till the **** loses it's solid adhesive quality. Then rub cleaner on little patches at a time, it will come off, however, remember to use different parts of cloth each time, as the stuff solidifies when removed and will scratch your treasured shiny surface. Spiralmind.
Old Apr 27, 2010 | 01:55 PM
  #32
XL50#674's Avatar
XL50#674
Chrome Cleaner works well, but you have to rub hard. I burnt part of a glove on my Z1000 header while changing the oil filter and chrome polish took it off with a bit of work.
Old Apr 27, 2010 | 02:13 PM
  #33
1Coastie's Avatar
1Coastie
Run the bike until the exhaust is just hot to the touch, spray some oven cleaner into a glass bowl (way away from bike... it'll eat paint!) take a small brush or Q-tip and apply the cleaner to the spot you need to remove, let it sit until the pipe cools enough to touch it easily (about 5 min.) wipe off with a cotton cloth.......done!
Old Apr 27, 2010 | 02:17 PM
  #34
redultra02's Avatar
redultra02
Try Goo be Gone and a rag worked great for me
Old Apr 27, 2010 | 02:40 PM
  #35
Geoff's Avatar
Geoff
I did the same thing once. I used EZ off Oven Cleaner. Let it soak for a while and don't get any on your paint. Steel wool will remove marks, but it will wear away chrome.
Old Aug 9, 2011 | 08:29 PM
  #36
MrMojo's Avatar
MrMojo
Originally Posted by 7/11 The Crapshooter
Hah, you folks are so out to lunch on this. Well except for one very smart individual that chose the penny any way. When the pipes cool off and the towel hardens you can use a penny or a nickel in a pair of vice grips and it will take the towel right the pipe. You would really have to go nuts to hurt the chrome on the pipes because the copper or nickel is very soft in comparison to the chrome. They won't scratch, you don't have to worry about any overspray hitting paint or some other area that really doesn't like things like oven cleaner and there is very little effort required.
+1 with the penny. I held it in my fingers so I could control the pressure and I just scraped off melted plastic from cold pipes. I also used steel wool, very light pressure, and some chrome polish. It took about 30 mins but it all came off using very light pressure.
Old Aug 9, 2011 | 09:48 PM
  #37
golfblues's Avatar
golfblues
Originally Posted by chuck2000RK
when the pipe is warm take a penny and softly scrape it. the penny is soft and wont sctratch the pipe as long as you dont push in to it.
Use a pre 1982 penny which is all copper & won't scratch.
Mel A
Nov 8, 2014 05:33 PM
Steelhammer
Detailing
Aug 30, 2010 08:48 PM
skidder
May 12, 2009 08:01 AM
gli.der
Apr 2, 2008 07:20 PM
az232
Mar 16, 2008 10:25 AM
