lowering the frontend
Old Apr 7, 2009 | 09:07 AM
roofer's Avatar
roofer
Default lowering the frontend
I have aftermarket forks on the wifes lowrider and she say's the bike is higher in the front now, under the fork plug there is a 2" spacer than the spring if I cut the spacer down will that lower the front end or is that going to mess with the suspension Thanks
Old Apr 7, 2009 | 09:09 AM
wcc083's Avatar
wcc083
Just loosen the lower bracket and slide them up a bit.
Old Apr 7, 2009 | 09:13 AM
cHarley's Avatar
cHarley
Ditto - loosen the triple tree bolts and slide the fork tubes up a bit.
Old Apr 7, 2009 | 09:24 AM
Da Gumpmeister's Avatar
Da Gumpmeister
Uhhh, BUT wouldn't that make it a "HIGH RIDER" vs a "LOW RIDER" ???
Removing, or 'cutting' the spacer, will NOT mess up your s'pension as bad as just sliding your fork tubes up. That will change your 'rake and trail', "COULD" (operative word) BUT not necessarily WILL cause handling concerns at high speeds. More times than not, it will NOT have any effect at all, BUT, it "COULD". Jus' wanted you to be aware of that. I have done that, myself, with no ill effects. BUT be Careful, WELL, that is, IF you want to keep her 'round.
IF you cut or remove the 'spacer', DOUBLE check, and then CHECK AGAIN, your clearance to front fender.
The 'actual' suspension is performed by the valving in the forks. IF you have 'soft' valving, and you remove/cut the spacer, you could possibly experience fender issues. BUT you will have to determine that as you go.
Old Apr 7, 2009 | 09:29 AM
roofer's Avatar
roofer
They are wide glide triple tree and 41mm tubes so I can't slide the tube up and the spacer is right under the top plug on the fork tubes
Old Apr 7, 2009 | 09:41 AM
Da Gumpmeister
ALL-Pro, 60k, propane. Uhhh, must be in the 'building trades'. BWahahaha (GEE, Gumby, ya think so, with a name like 'ROOFER' )
Can you get your paws on a 1" spacer, to 'try' it BEFORE you cut the 'original' spacer that came with it??? And would 1" be enough for her???
When you do this (remove spacer), it will bottom out, 2"s sooner than NOW. (In reality, you are putting the 'tube' 2" deeper into the 'slider'.) IF she doesn't bottom out, 'should' be good to go for ya. My only concern, w/o seeing your spring and spacer, is that the spacer has any sort of a 'keeper' or 'flange' on it, to keep spring 'centered' in tube. To verify, look CLOSELY at the bottom of your 'cap', and the bottom of your spacer. You may need to turn the spacer down on a lathe, in order to 'keep' the bottom of the spacer in tact, for the spring alignment. AGAIN, W/O seeing what you have, one step at a time.
Old Apr 7, 2009 | 09:59 AM
roofer's Avatar
roofer
The plug is the same as stock harley and I don't believe there is any flange on it it looks the same on both ends
Old Apr 7, 2009 | 10:13 AM
Da Gumpmeister
IF it were here, I'd pull 'em, and then hit the 'bricks' hard and fast, to see if it bottomed out. SLAM on the front binder major time, anything to get it to 'bottom out'. IF you do not get the bottom 'clunk', good to go, Sir. Does she ever ride 2 up?? IF so, you may have to go with shorter tubes, I KNOW, it sux and cost$$$, to keep from bottoming out when she is 'loaded' down.
BUT, IMFUO, that is going to be a 'rarity', unless you are strapping on 500#s.
Old Apr 7, 2009 | 10:31 AM
roofer's Avatar
roofer
She never rides 2-up and she is not a hard rider at all I'm always waiting for her
Old Apr 7, 2009 | 11:47 PM
GT_RoadGlide's Avatar
GT_RoadGlide
The first question is, since this is an aftermarket front end are the forks longer than the oem? One way to lower the front end is to change or add rebound (top out) springs. This will force the slider further into the fork tube. Call Progressive Suspension and ask them about lowering the front end. If you are comfortable taking the forks apart check to see how they were assembled. If you know who manufactured then call and ask for a diagram (assembly/disassembly instructions).
ffatboy03
Nov 5, 2013 01:05 PM
Dyna7
Jun 4, 2012 01:25 PM
hogwyld79
Jan 9, 2007 07:44 PM
kaduku
Jun 18, 2006 05:31 PM
Terry TK
Feb 24, 2005 10:55 PM
