Fork extension?
Old Jun 2, 2012 | 04:35 AM
Dyna7's Avatar
Dyna7
Default Fork extension?
Hey everyone
i just got my Harley and it the front end is way to low, i scrape if i barely go over anything, i re-adjusted the rear shocks and raised it, but it looks like he has collapsed the front end?, the forks are really only showing about 2-3 inches of area able to absorb shock? is there any way he just collapesd them and i able to re-extend them? or has it all been changed
Thanks from Hawaii !
Old Jun 2, 2012 | 04:47 AM
Dyna7's Avatar
Dyna7
Here is a picture of the front
Old Jun 2, 2012 | 05:18 AM
Blk and Chrome's Avatar
Blk and Chrome
It's been lowered quite a bit, depends on if the tubes were changed. Most likely the tubes are -2 with a 2"lowering in the ft if so you can remove the tubes take off the top cap and put a longer spacer in there to increase the lenth and travel ..if they are -4 tubes then you would have to change the tubes
Old Jun 2, 2012 | 05:27 AM
Dyna7's Avatar
Dyna7
What is the best way to figure out if they are -2 or -4?
and if he added a 2" lowering kit in the front how can i remove that? or remedy it?
Old Jun 2, 2012 | 09:12 AM
heybaylor's Avatar
heybaylor
jack up the front , see how much down travel there is ..
Old Jun 2, 2012 | 09:46 AM
Tee&Vee's Avatar
Tee&Vee
What is stock for this model? 23" overall?? I also find a lot of help in the Evo & classic subforum 90 GA.
Old Jun 2, 2012 | 09:47 AM
Tee&Vee's Avatar
Tee&Vee
maybe 26 inches
Old Jun 4, 2012 | 01:25 PM
Dyna7's Avatar
Dyna7
Thanks, i jacked the front up and there was barely any drop
looking like im going to have to get new tubes
i will keep yall updated
BMWelch09
Jan 17, 2016 07:46 AM
SpicOfTheDevil
Mar 8, 2011 08:33 PM
09DynaRyder
Mar 19, 2010 11:56 AM
London dude
Mar 27, 2009 11:13 PM
MAX EVO
Nov 4, 2006 08:31 PM
