fried C02 sensor
Old Apr 17, 2009 | 07:10 AM
u000drl's Avatar
u000drl
Stage III
Unhappy fried C02 sensor
I recently put some fuel injector stuff in my 08 sporty, cranked it up, had it running (on kickstand) all of a sudden major smoke coming OUT OF THE OXYGEN SENSOR (not the exhaust) THATS IN THE TOP OF THE TAILPIPE! i shut her down, then restarted (bike now upright) and it seemed ok, but when it was smoking it smelled like something was seriously burning. seems ok now-any ideas what i did? if i fried the 02 sensor will it still run ok? thanks, miles
Old Apr 17, 2009 | 07:16 AM
FastHoss's Avatar
FastHoss
Why did you put something in the gas?
Old Apr 17, 2009 | 08:33 AM
DannyZ71's Avatar
DannyZ71
You didn't put the entire bottle of cleaner in the tank, did you? Most of that stuff is for 18-25 gallons worth of gasoline. You only need a tiny bit for a 5 gallon, or less, tank.
Old Apr 17, 2009 | 09:21 AM
Low_Wider's Avatar
Low_Wider
Default Cooked Sensor
If you cooked the O2 sensor you should be throwing a DTC code.
Old Apr 17, 2009 | 11:05 AM
Cheesecake's Avatar
Cheesecake
did you put anything on the threads when you installed the 02 sensos that might of gotten of the pipes?
no exhaust leaks??
Old Apr 17, 2009 | 10:09 PM
Low_Wider's Avatar
Low_Wider
Default DTC Check Procedure
Miles,
Here's the procedure to check your DTC codes. You should see a P0134 and/or P0154 for a bad O2 sensor.
File Type: pdf
Andy02
Mar 27, 2018 10:30 AM
TexasVet
Jul 1, 2012 06:38 PM
KCFLHRC
Nov 5, 2011 12:07 AM
jrc757
Oct 28, 2011 07:08 AM
blueangel73
Sep 8, 2010 09:14 PM
