Spark plugs
Old May 19, 2009 | 03:48 AM
xxxflhrci's Avatar
xxxflhrci
Originally Posted by cadman311
I try the platinum plugs and did not care for the way bike ran.
My bike runs great with platinums. My first set of stock plugs lasted about 6500 miles and got a miss. Replaced with same and got same results. Replaced with platinums and ran them over 30k miles before changing them and then only because I had added cams and a tuner and wanted to monitor the burn on a new set of plugs. The second set of platinums now have 22k miles on them and are doing just fine.
Old May 19, 2009 | 04:24 AM
Fossil's Avatar
Fossil
Default Spark Plugs
With today's electronic ignition and fuel injection. Those plugs look good from the photos. Look in beside the ceramic and see what color or build up may be there. Every 3-5 years I change my spark plug wires. They don't cost that much and with the carbon filler it wouldn't hurt. Fossil
Old Jun 1, 2009 | 09:31 PM
global force's Avatar
global force
Default Spark Plug Color
I have an 07 FLHP. This is my first EFI bike. I changed the air cleaner, exhaust, and installed a V&H FuelPak last week. I also put a new set of plugs in so I could see if I was running too rich or too lean. The bike performs awesome. Power everywhere, smooth acceleration, no decel pop. I have put about 250 miles on it so far. I pulled the plugs to take a look this evening and they still look brand new. Not too light, not to dark....they look new. How is this possible?
Old Jun 1, 2009 | 10:49 PM
hpfatboy's Avatar
hpfatboy
Plugs should have a TYPICAL TAN COLOR, like a ROASTED MARSH-MELLOW done on a CAMPFIRE.
Old Jun 1, 2009 | 11:05 PM
oldairboater's Avatar
oldairboater
I hope you antisieze the new plugs before installing. Saves a lot of future headaches.
Old Jun 2, 2009 | 07:39 AM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by fbhawg
Why in the world would anyone change plugs at 5 or 10,000 miles? I can see it if you have a problem buts thats just crazy. JMO
The '06 manual sez to change them at ten which I did.They actually did not look worn.
I Put the SE platinums in at that time and now have 39000.
Old Jul 18, 2009 | 07:15 PM
vandykemc's Avatar
vandykemc
When do you all change the plug wires?
Old Jul 18, 2009 | 07:35 PM
bagga's Avatar
bagga
i change mine if the bike has trouble starting in the spring. some plugs have lasted 5 years some have lasted 5 days. if it ain't broke don't fix it. i run the $1.29 champions.
Old Jul 18, 2009 | 10:12 PM
G Rod's Avatar
G Rod
Originally Posted by frankjake
Not to hijack the thread but has anyone tried the Iridium plugs.
Two guys I ride with use them and swear they make a diffference in performance and fuel mileage.
I have not tired them as my bike only has 3,000 miles on it, but I might give them a try when they are ready to be replaced.
I now have 13,000 miles on the ND Iridiums I installed. They look good when I have checked them and perform well but are expensive.
Old Jul 18, 2009 | 10:47 PM
harleydavis's Avatar
harleydavis
From what I could see from the pictures, your plugs looked fine. Could be running just a little rich, but as others have said......it is better to be a little rich than lean.
Doug S
EVO
23
Jul 20, 2018 09:02 AM
mjwebb
Milwaukee Eight (M8)
14
May 25, 2017 11:53 AM
UltraZac
Apr 17, 2017 04:47 PM
Marsh
Feb 10, 2011 02:31 AM
SURFOR Chop
Apr 22, 2010 05:35 PM
