floorboard insert vibration question
Old Jun 20, 2009 | 12:48 AM
RandyS's Avatar
RandyS
Default floorboard insert vibration question
Guys, switched my front floorboards to skull theme...compared to the stock that came with the boards, way more vibration reduction....
Wife rode the passenger floorboards with stock since spring...just bought the skull hd theme for her passenger boards..went for ride tonight she says my feet are numb from vibrating want the old ones back!!
What the ....so I check it out and yes the stock has an airspace in the rubber to allow for some movement...and when you put the chrome ones on..there is no big rubber ball vibration dampener like the front....checked buddies egclassic with nostalgic theme..no movement on passenger, lots on driver...
HElp...how can I get these things to have some dampening to them...they look so much better than stocker rubber....
Thanks.
ps this is on my 06 lowrider.
Old Jun 20, 2009 | 10:15 AM
DannyZ71's Avatar
DannyZ71
Thanks.
How about rubber spacers on the mounting bolts? That would isolate the entire footboard from the frame. May also be your cheapest solution.
Old Jun 20, 2009 | 12:28 PM
RandyS's Avatar
RandyS
Hey I was wondering that myself....can a person get it tight enough though so the are holding on well enough but still dampening at same time...
Old Jun 20, 2009 | 12:38 PM
DannyZ71's Avatar
DannyZ71
Should be able to. The engines are rubber mounted.
Old Jun 20, 2009 | 12:50 PM
RandyS's Avatar
RandyS
Good point!
Old Jun 24, 2009 | 11:50 PM
RandyS's Avatar
RandyS
Anyone have any thoughts on this - not sure how I would rubber isolate these without proper supports so they do not bend too much....
What would people suggest for isolators that might work? Thanks
streetglidetroy
Dec 29, 2011 05:56 PM
rysonn
Oct 24, 2011 10:17 PM
edsstuff57
Oct 26, 2009 06:28 PM
mpr3369
Oct 24, 2009 12:35 AM
RandyS
Jun 27, 2009 09:55 PM
