Passenger floorboard inserts problem
Old Oct 20, 2009 | 11:13 AM
mpr3369's Avatar
mpr3369
Default Passenger floorboard inserts problem
I'm in the process of installing some skull inserts. The directions are kind of vague. I did it exactly like they say but I can't get the outside of the inserts to set, the inside near the hinge point is right in place but the outside is supposed to set on two little square studs but I can't get them to set correctly. Is there a trick??? By the way they are the swept wing style floorboards in case that makes a difference. Thanks for any help you can give me!!!
Old Oct 20, 2009 | 05:34 PM
dawg's Avatar
dawg
Sounds like the rubber dowel pins didn't pop into the mating holes correctly.
Old Oct 20, 2009 | 06:16 PM
moondog99's Avatar
moondog99
+1, pull them off lube them up and reinstall!
Old Oct 20, 2009 | 07:37 PM
ENTERPRISE's Avatar
ENTERPRISE
ya,more lube.
Old Oct 24, 2009 | 12:35 AM
mpr3369's Avatar
mpr3369
Thanks for your help. I did put more lube and the dowels went right in.
MarcV125
May 2, 2016 08:37 PM
streetglide6
Mar 7, 2016 04:55 PM
murph
Jan 3, 2013 06:28 AM
Bradley Jones
Jun 30, 2009 12:35 AM
Trailfndr
Sep 13, 2008 08:37 PM
