103 and cams?????
Old Jun 26, 2009 | 07:30 AM
dr's Avatar
dr
Default 103 and cams?????
I just purchased a 07 Street Glide with 6100 miles on it with a 103bbk. After researching with the dealer that did the build on the bike when new. I found out its a 103 stage one using stock cams. Last bike being a 05rkc with a 88 and a stage one I do not know much about the 96/103 motors other than this one feels very strong compaired to my 88inch did. Dealer said stock cams are go enough. Are they? I figure there is more knowledge on here than at any one dealership. Are the 96inch stock cams good enough? or should I opt for a cam change? if so what cams work best? thanks
Old Jun 26, 2009 | 07:47 AM
petemac's Avatar
petemac
IMO a stock cam with a big bore build makes no sense. Do a search for 103 and cams and you'll see TONS of info. Andrews, HQ and others make great cams.
Old Jun 26, 2009 | 08:02 AM
dr's Avatar
dr
I keep hearing go with Woods TW6-6, but I do not know much about them. Guy I bought the bike from said it has 255s in it. Dealer said they did a stage 1 bbk.[?] which uses stock cams. But this dealership has had a big shake up in their service department over the last few months, just about everybody that was there left, so I do not know reather to belive them or not about the stock cams. The bike pulls like a freight train upto to @4000 then I can feel it get flat after that.
Old Jun 26, 2009 | 08:50 AM
bennenrkc's Avatar
bennenrkc
I bet it has the 255 cam in it, sounds like the rpm range that my 255 103 runs at.
Old Jun 26, 2009 | 09:22 AM
mavrickFLHR's Avatar
mavrickFLHR
I've also "heard" and I'm the first to admit this is just something I heard and I don't really know or have experience with.. that a 103 with good cams is just as good and is actually more reliable than the 110 SE motor.. if there are any of you who actually know, I'd very much appreciate your thoughts..
Old Jun 26, 2009 | 01:35 PM
fripple's Avatar
fripple
throw the SE-204 in it.
Old Jun 26, 2009 | 03:53 PM
nytryder's Avatar
nytryder
Just did a stageII 103'' w/255 se cams. It runs real good.
Old Jun 26, 2009 | 03:59 PM
GregH's Avatar
GregH
A 103 with good cams will usually run stronger than a stock SE 110, which has 80 hp. A well built 103 can have over 100 hp. However, I have a well built 110 that seems to have it over on the 103's..... at least around here. The built 103 is a great motor and quite a bit less expensive than the 110 build.
Old Jun 26, 2009 | 04:22 PM
vtwin1340's Avatar
vtwin1340
255 cams come in the 103 kit. Might be the kit "stock" cams, I doubt if they are the stock cams that came with the 96.
Old Jun 26, 2009 | 04:47 PM
oct1949's Avatar
oct1949
+1
The 103 kit includes the SE 255's and Usually Flat top pistons, he might have meant that buty just didn't say it that way..
