Front end feels unbalanced
Old Jul 14, 2009 | 09:43 PM
HarleyX89's Avatar
HarleyX89
Default Front end feels unbalanced
I was wondering if ne1 could help me diagnose why my bike feels off and what exactly could cause it. On some turns lately my bike feels like the weight shifts on evenly. My pressure in my forks is good, I was pretty low on oil but I fixed that and my tire psi is at 35lbs but i was told 38 psi in the front and 40 psi in the back would do me some justice could that really be it? I'm going to buy the right nozzle for my dad's air compressor tomorrow but thanks for any and all replies guys!
ride safe
Old Jul 14, 2009 | 10:02 PM
oct1949's Avatar
oct1949
check the spokes and wheel weights to see if anything is loose, along with the tire pressure, and fork oil.
Old Jul 14, 2009 | 11:00 PM
outlaw0013's Avatar
outlaw0013
Besides what was posted above check your wheel bearings also.
Old Jul 15, 2009 | 12:53 AM
HarleyX89's Avatar
HarleyX89
all right thanks guys I'm gonna check all I know how to tomorrow and if I don't find anything i'm getting a little guidance from my buddy who is a mechanic. Thanks a lot guys. I'm scared for my baby, I'm broke as **** and I couldn't imagine not being able to ride!!!!!!!!
Old Jul 15, 2009 | 07:53 AM
FastHoss's Avatar
FastHoss
How about uneven weight in the saddle bags
Old Jul 15, 2009 | 08:08 AM
harleyguy5571's Avatar
harleyguy5571
Have you had your rubber mounting system checked and swing arm. If your bike is the same as mine, 90 FXR, you might want to have it looked at. I was having the same problem and it turned out that most of that stuff was just wore out. The way it was explained to me was the motor, trans and swingarm are all linked together through the rubber mounting system. All the of those pieces need to be working together for the bike to handle right.
Hey if I'm wrong don't bite my head off guys. I'm still learning this stuff too
Old Jul 15, 2009 | 08:21 AM
cadman311's Avatar
cadman311
Check to see if your front has tire bumps on it.
Old Jul 15, 2009 | 08:33 AM
Johnnyiroc's Avatar
Johnnyiroc
got any one saddle bag loaded heavier than the other? Check your tires for strange wear, you might want to check the bearings out too. Got any slight wobbles or new vibrations? Check out the rear shocks?
Old Jul 15, 2009 | 12:37 PM
iceman336's Avatar
iceman336
check the steering head bearing tension as well. Get the bike up on a centre stand and centre the forks to the frame. The wheel should stay in position for up to 1" in either direction before flopping to the full turn lock. If the front end moves immediately, you don't have enough tension in your steering head. It can make a bike feel loose in the turns as well...
Old Jul 15, 2009 | 12:39 PM
HarleyX89's Avatar
HarleyX89
Getting ready to go see my buddy soon. Thanks for all the great suggestions guys I'm looking into it. I looked all the tires over and every inch of my front end and so far everything checks out. Hopefully it's nothing major but I'm going to the shop to have him take a look, I'll get back to you on what I find. Thanks!!!!
