Stiff first shift after sitting
Old Jul 21, 2009 | 09:47 PM
ILTim's Avatar
ILTim
Default Stiff first shift after sitting
Seems shifting from 1st to 2nd takes a LOT more force than usual, but only the first time. Happens in the morning and after sitting a while, dosent seem to happen at short stops. I'm thinkin clutch plates sticking or something? Catches me off guard, have to clutch again and make another run at it.
Old Jul 21, 2009 | 09:52 PM
oct1949's Avatar
oct1949
What yr bike, tranny oil used?
Old Jul 21, 2009 | 10:12 PM
mjsawatzky's Avatar
mjsawatzky
Mine too. Never really thought too much about it. Works fine when warm. I'm curious now to see what sort of discussion this generates.
Old Jul 22, 2009 | 12:48 AM
AZ Rider's Avatar
AZ Rider
After backing out of the garage, that first shift into first sounds like the transmission could drop on the ground. Just letting me know it's there...
Old Jul 22, 2009 | 07:07 AM
99 Conv's Avatar
99 Conv
I think I would check the oil level in the Primary before Starting it up and make sure its not over filled first..Sometimes when all the oil drains down and it's cold/thick the clutch will not fully release....Just a thought...
Old Jul 22, 2009 | 08:58 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Ding, ding, ding...99conv. got it . The clutch plates stick together from the oil cooling and getting to it's cold viscosity. It may help to pull in the clutch a couple of times while the motor is warming up from first start after sitting. You just want to seperate the plates from each other . The viscosity may have a part this also, don't know what HD Formula+ viscosity is, bet it's closer to 20w50 than 10w40.
amkaos
Apr 15, 2016 09:14 PM
blackflame
Jun 24, 2012 05:45 PM
Cycopath
May 15, 2010 06:41 PM
glebo
Aug 7, 2007 08:58 AM
TQ
Jun 17, 2005 08:30 PM
