thats great, its a huge hurdle to jump, i have a family member that fell of a horse and broke his neck and as soon as he started to get mobile his confidence and spirits where lifted big time.
I hope he continues to battle his disabilty.
By the way YOU guys that contributed to this act of kindness are awesome Individuals that got together by this forum to change a guys life. FCUKEN AWESOME
There was a change in circumstances for the gentleman that offered up a derby cover and therefore will not be able to hook us up. If anyone has any leads on a stock black derby, please let us know. Again, functionally, there are not problems with the current cover - just deep grind marks.
Also, with the limited mobility of Bill's new ankle and foot, we think it would be a good idea to pursue a mod for front and rear brake integration. I'm looking for options as far as set-up. I'm am reading up on the issue and if anyone has any links, suggestions, information or other help they want to share, we would appreciate the assistance.
I was thinking about this after reading your post. My thoughts came to utilizing your front lever to get some back brake too as I think your thoughts were too. I found this site for disabled riders and one of them used what they call a cable splitter used on racing bikes with double drum brakes. Since your front brakes are 70% or so of your braking power, you may be able to use a configuration like this to split your front cable into two, and work the ratio out so the front brake will receive the correct amount of force. My thoughts are as the picture shows the "bar" distributing equal loads, possibly make the pivot point of the bar favor the front brake, and in turn engage the rear brake with less pressure after the front brake has engaged. Hope this helps http://www.mtb-amputee.com/images/CableSplitterTwo.jpg http://www.mtb-amputee.com/motorcycl...m#Jeff%20Cohen
Can you use an automotive adjustable proportioning valve? Take the line from the front brake and route it to the valve, then from the valve to both brakes. This will allow you to tweak the brake bias any way you need to based on rider weight, passengers, etc.
That is the direction I was thinking, but I have concerns. Mainly, what about when you only need rear brake, like maybe a slow moving situation in gravel. Bill knows he is going to have to be a lot more cautious of his actions and situations he gets into, but there is still the potential when he will only need a little rear, no matter how hard he tries to avoid it.
I called a few shops that deal with disabled equipped bikes and asked for their suggestions, and all they are willing to suggest are - trikes, or kits like the 2 thousand dollar klick setup. The klick is not a good set up in my eyes because you have to put the front brake on to use the rear. That may be fine for a trike, but not a on two wheels. Same as valve setup basically.
I have read some stuff online about disable riders using just front brakes, and that is their choice. A good rider can get by for sure. It is obviously "do-able", but there is still a serious risk there to be weighed.
