trailer tie down straps
I used soft-ties around the forks right where they mount to the fender and was careful not to pull them too tight. Want to make sure I'm not spreading the forks apart. Is this OK?
gary
Never, never strap to the handlebars or you may bend the bars. Not good when you get to your destination and your right or left hand is a few inches lower than the other. They will bend. So will the engine guard so don't use your hwy pegs for a mounting point either.
Let me tell you what I use and maybe it will help.
I use 3" wide straps with cranks on the front and the same straps on the rear but with a slide and lock type chuck. Each strap has an S hook on either end. I use softies on all four mounting points on the bikes. Two in the front and two on the back.
I have an enclosed trailer but this will work on an open trailer as well if you have front wheel chocks and floor rings. (I am taking for granted that you do.)
Hook the rear up first. Try to use the passenger board mounts with the softies then hook the straps to the softies then the floor rings and tighten them. Use your foot for leverage, if you can, and continue pulling on the loose end. If an S hook gets close to your pipes then wrap it with a towel.
For the front I place the softies on the frame where the top of the engine guard mounts then put a piece of foam between the strap and the fender if the strap is too close when hooking to the floor ring. Any old pillow will do. Make sure the strap cranks are at the floor, not the bike.
Once the front strap is in place I crank the straps tight which pulls the forks down into my Condor wheel chocks. I do one side a little then the other. Do not bottom out the forks. Simply pull the forks down a few inches until you feel it is tight enough to ride then give it one more notch on the crank. If you hit a bump the forks can still move but the straps will stay tight.
Have been doing this for years with no issues, no scratches, no bent bars. Some guys like the kickstand down other like it up. I like it down for no other reason than my mental state.
If you have an enclosed trailer that is not very wide then stick some foam tape on the wall where your mirrors may hit. This way it won't scratch your chrome if the bike rocks. Mine don't but I like the protection there anyway.
