what happens if.....
Old Aug 7, 2009 | 02:44 PM
RHPAW's Avatar
RHPAW
I thought the little light meant that your 2 minute egg was ready?
Old Aug 7, 2009 | 03:05 PM
FastHoss's Avatar
FastHoss
There is a strip inside the manifold that when gets wet turns red.Your warranty is now void.This little stunt could have ended in ijury or death.Read your manuel if you even have one.
Old Aug 8, 2009 | 08:56 AM
vinnypie's Avatar
vinnypie
what does that mean it could have ended in injury or death? it died on me on the penna. turnpike. warranty has been up so i knew it would cost me. who pulled a stunt, i'm not evel knievel......WTF!!!!!!
Old Aug 8, 2009 | 12:52 PM
NiteOwl's Avatar
NiteOwl
Strip in the Manifold? joke right?
Old Aug 9, 2009 | 04:54 PM
emwolb's Avatar
emwolb
it's an old trick used for a long time for cleaning the cylinder heads and piston crowns. the water will enter the chamber and immediately turn to steam, thereby steam cleaning the top end of the motor. just check your electrical connections including plug wires and you should be good to go.
Old Mar 23, 2010 | 02:54 AM
j1mmy's Avatar
j1mmy
if there is enough water the engine will stall before there is enough of it to cause a problem.. to cause a hydrolock you would have to literaly dump a bucket of water in the intake at high rpm, or ride into a lake, a hydrolock in a car is from a blown headgasket, or cracked block/head, the cylinder sucks in antifreze..theres ony a slight chance of that on a harley..
Old Mar 23, 2010 | 04:45 AM
oldncrzy's Avatar
oldncrzy
a little bit of methyl hydrate might help. If I get watery gas (that sounds disgusting, doesn't it) I will use some carb/injector cleaner available anywhere. Water is a way of life for a biker dude/dudette
WildThang
Nov 6, 2013 10:07 AM
jisananimal
Jul 19, 2011 12:13 PM
johnzlee
May 19, 2009 08:15 AM
jammer1
Exhaust System Topics
Jul 26, 2006 11:55 PM
JSW
Jan 14, 2006 09:16 PM
