My 96 1200 sporty started having charging problems last year, I pulled the battery and had it load tested and it was bad. New battery. About a month later it lost all electrical power and left me stranded an hour away from home, got it towed home and tested the stator and it was bad. New stator. Last week I noticed the battery was dragging when I started the bike. Pulled the new battery had it load tested and it had a bad cell. New battery. Thursday it started dragging again so I tested the stator and it is good, then I read the voltage at the battery and it was only at a little over 11V at 3000 RPM, so I changed the voltage regulator, the back was bowed out and cracked. Took a ride today and guess what, the battery is dragging again. I measurerd the voltage again at the battery and get only 12.45 volts. Of course I checked all the grounds and even did continuity checks on the wires. Any body have any idea's?
I had a similar prob and doing all the charging system tests proved inconclusive (the stator test passed to a point as did the regulator test!!)
I pulled the primary and found that the rotor over the stator had ground off all of its teeth!
Luckily they were held in place by the magneic field around the stator or it could have been catastrophic.
Whoever had built the primary had not installed Loctite on the nut holding the rotor in place and the constant motion had worn the cogs away. I assume it was from the factory like this.
Anyway, I installed a new rotor and all is well. Showed my dealer the old one and they were not particularly interested. Like that came as a surprise.........
