2005 HD wide glide
Old Jun 13, 2006 | 09:58 PM
pilot_m_c's Avatar
pilot_m_c
Stage I
Default 2005 HD wide glide
i have a 2005 wide glide just purchased 2 days ago. i looked at the oil level on it and it was 1/8 of an inch above the add quart line and the oil was pertty dark so i assume the oil wasnt changed when i bought it. when i saw this i figured it was low. so i took the spark plugs off to check and see if the engine was burning oil. well on one of the plugs it had a little oil in the threads of the spark plug and the other spark plug was clean. does anyone have any idea on what could be the problem and is that oil level normal for that bike?
Old Jun 13, 2006 | 10:26 PM
WoodyHD's Avatar
WoodyHD
Default RE: 2005 HD wide glide
The oil dipstick on my Softail has the min/max hash marks on it but my owners manual says you can fill the oil tank up to the weld of the filler neck (which will take it considerably above the max level marked on the dipstick). I can only presume that this is the same for Dynas.
Old Jun 13, 2006 | 10:36 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I would change the oil and the plugs and see if it re-occurs before I did anything. My $.02.
Old Jun 13, 2006 | 11:12 PM
murphdog's Avatar
murphdog
There was a problem with valve seals on 05's. Yours should still be under warranty, see your closest dealer.
GibsonSG05
Sep 11, 2013 02:52 PM
FatBoyBull
Apr 17, 2013 08:05 PM
Revereamg
Nov 11, 2009 10:06 PM
Road King Kid
Oil Archive (no new posts)
Aug 31, 2009 07:32 PM
eddy666
Jan 8, 2009 11:12 AM
