1. Oven cleaner. Use aluminum foil to protect your painted areas from the overspray.
2. 0000 steel wool, some say this finest steel wool will not scratch chrome. I have not used it for that.
Just for the record, 0000 steel wool WILL scratch chrome.
I've used 4 ought steel wool on chrome and aluminum for many years and never noticed any ill effects. I've never used it dry,always in conjuction with some kind of chrome polish.
I had some acetone & was going to try it, but the can had leaked it all out. Someone expressed that the acetone may be "rough" on the chrome. Anyone know for sure?
ORIGINAL: Cessna172
EZ Off oven cleaner and a wooden scraper works well for plastic, boots, flesh, etc.
I was going to try EZ off, but when my wife went to the store to buy some she read on the label, "do not use on chrome", so she didn't get it.
ORIGINAL: 87lowrider
Did you try Blue-Job.................it works for me
They make a product called GOOF OFF I think it will take anything off...It may be acetone, Never looked at the ingredients just no it was some bad mamajama.
Im not sure, but if you get em cold, and then use a very exspensive penetrating oil called Kroil, it might get between the stuff and the chrome and then slip right off. Kroil can be found at a machine shop or their supplier, pricey, used to be 10$ for one can, probly more now, but the stuff frees up stuck bolts overnight and it works for that really well so you wont be out if you try it.
