when to replace lifters
Old Oct 8, 2009 | 09:48 AM
Ern1's Avatar
Ern1
Stage II
Default when to replace lifters
I have a 2007 Road Glide and have been lucky enough to put 50,000 miles on her. My local dealer suggested replacing the lifters over the winter. I don't have any lifter noise and the bike runs strong.
Is there an there a usual mileage that this maintenance is preformed or wait until I start hearing signs of wear?
So, should I replace them?
Old Oct 8, 2009 | 09:53 AM
huffhuff's Avatar
huffhuff
i wouldn't. roller lifters last a long time and even if you begin to hear a little noise, roller lifters are inherently a bit noisy. a close inspection is a better plan.
Old Oct 8, 2009 | 11:03 AM
Ribitt's Avatar
Ribitt
Cool
my 00 had 100K when i traded it for the 07 and it had stock lifters still in it. The 07 has 53K and I see no reason to change them, unless you feel the need or start having problems.
____________________________
07UC, Rinehart TD's, SERT, SE A/C
S&S Geardrive, Andrews 26 Cam
Old Oct 8, 2009 | 11:04 AM
widowmaker221's Avatar
widowmaker221
If it ain't broke don't fix it! It should be fine for many more miles.
Old Oct 8, 2009 | 11:08 AM
Harley_Dude's Avatar
Harley_Dude
Lifter no, but better check cam tensioners if you haven't yet.
Old Oct 8, 2009 | 11:22 AM
oct1949's Avatar
oct1949
When I done the cams this spring at 16k my dealer recomemded putting in new lifters. Since then I've talked to a wrench who does my sons work at another dealership and he said that didn't hurt but I wouldn't have had to. Normally he changes them only after 20k and over, he said the stockers should go 100k with good maintenance which almost all of us do..
If U do deciede to do them, I would think seriously about some bolt in cams if U haven't already done them. The cams will make a really good improvement to the motor in power and helps cool her down. Plus my mileage went up a couple mpg's.
U should be able to get the winter special price anyway and save several Hundred $$. Sounds like they are trying to drum up some winter business..
Old Oct 8, 2009 | 11:38 AM
harleydavis's Avatar
harleydavis
Typically, lifters can last a long time, but 50k in 3 years is a lot of mileage.
Old Oct 8, 2009 | 12:13 PM
FastHoss's Avatar
FastHoss
I think you are on borrowed time.Change lifters,cam chain tensioners,cam bearings,you will be set for another trouble free 50,000 -- hopefully
Old Oct 8, 2009 | 03:37 PM
harleydavis
I couldn't agree more with with the above comment.
Old Oct 8, 2009 | 04:19 PM
Ern1's Avatar
Ern1
Stage II
Default Thanks !
Good points
