Cold fingertips!
Old Oct 14, 2009 | 08:01 AM
Handycam's Avatar
Handycam
Default Cold fingertips!
First real cold snap of the year around here. Rode in today, 32 degrees. I was perfectly warm & comfortable in my Tourmaster over-pants and FXRG fabric jacket. Only part of me that ruined the experience was the tips of my 4 middle fingers.
I was wearing my HD Windshield gauntlet gloves and some glove liners. The rest of my hands (backs, knuckles, wrists) were toasty. But my fingertips started to get numb after about 1/2 hour (25 miles hiway).
Is it just me, poor circulation in my older age? Or my glove setup? The way I grip the grips? The mini-apes?
Any suggestions, or anyone else come across this? It's a drag since I am comfortable riding to work on mornings like this but this numb-finger thing might make me re-think that.
Old Oct 14, 2009 | 08:04 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Heated gloves might do the trick. I found that my cold weather gloves are kind of tight and cause several of my fingers to go numb due to the tightness compared to my warm weather gloves. Also, you can look into hippo hands.
http://www.hippohands.com/
Old Oct 14, 2009 | 08:06 AM
GeorgiaGirl's Avatar
GeorgiaGirl
Madame Moderator
In cold weather I have the same problem and it doesn't matter what gloves I wear unless they're heated. I got a pair of heated HD gloves off of eBay that plug into my bike and have been worth every penny. Unlike heated grips, the warmth is also spread over the tops of my hands and makes all the difference when in the wind.
Old Oct 14, 2009 | 08:25 AM
reynoldss's Avatar
reynoldss
4 middle fingers, you must shoot a heck of a bird.
HARLEY-DAVIDSON COLD WEATHER GAUNTLET GLOVES: $80 won a cold weather glove shootout.
We imagine Commodore Perry wore these kinds of things on his North Pole assault -- they have the ultralong gauntlets that go up to your forearms. These gloves are made completely of premium, drum-dyed leather, with a heavy-duty 150g Thinsulate lining and an insert of water-repellent Aqua-Tex in case any liquid should sneak past the beefy hide. A soft, breathable nylon lining wicks away moisture inside. Two adjustable leather straps at each cuff adjust the gauntlets and are embroidered with the Harley logo.
Cheers: Excellent gauntlet coverage; comfortable lining and solid leather construction. If you're going to Alaska, pack a pair. These are the warmest gloves here.
Old Oct 14, 2009 | 08:30 AM
Theo's Avatar
Theo
Another vote for heated gloves. I've tried so many gloves, even tried tying plastic bags around some, but the only ones that worked were the HD heated gloves. Also, a low tech solution would be to get some mittens, and throw one of those heat packs in there.
Old Oct 14, 2009 | 08:34 AM
geezer glide 56's Avatar
geezer glide 56
Originally Posted by GeorgiaGirl
In cold weather I have the same problem and it doesn't matter what gloves I unless they're heated. I got a pair of heated HD gloves off of eBay that plug into my bike and have been worth every penny. Unlike heated grips, the warmth is also spread over the tops of my hands and makes all the difference when in the wind.
I have the same problem, i have been thinking the heated glove route myself, You might have convinced me me to go ahead and do it. I haven't wanted to put heated grips on the bike anyway,They are too unreliable.
Old Oct 14, 2009 | 08:40 AM
Handycam's Avatar
Handycam
I knew someone would say that ;-) I meant the two in the middle, on each hand. For some reason pinky and forefinger did not get cold.
What about the ones with their own battery? I'd rather not start messing with wiring on the bike. If I had a touring bike, maybe. But on the street bob, and for the commute and occasional cold weather short ride I don't think it's worth it.
Old Oct 14, 2009 | 08:43 AM
GeorgiaGirl
Madame Moderator
Do you use a battery tender? I plug my gloves into the battery tender plug on my bike via a converter plug. No hardwiring necessary other than that. They have an on and off switch. Some even have a dial thermostat. Gerbing makes good heated gear too.
Old Oct 14, 2009 | 08:50 AM
RACKnRAIL's Avatar
RACKnRAIL
I'd rather have cold fingers than be seen with those hippo hands on my bike. They are the ugliest motorcycle accessory I have ever seen. Seriously though, the heated gloves are the only option, imo.
Old Oct 14, 2009 | 08:51 AM
JBA111's Avatar
JBA111
the HD gauntlet gloves work real good for awhile or till you hit 40mph and above on days that are in the 40s. above that speed and you need the heated gloves. if you ride on days below 40* spring for the heated gloves.
I've had heated gloves, heated socks and the heated undercoat for several yrs now and I ride an ultra. so if the sun is out and it aint freezeing I am subject to be out ridein somewhere. and even with heated gloves the finger tips will get cold when the speed gets up or the temps drop too low or your just out ridein too long.
heres a tip, go put on the gloves and wear them for an hour at the store/dealer whatever. reason is if they have a tight spot it may take a half hour to show up with tingling numb fingers. at the dealers you can try another pair, if your on the road they are yours and numb fingers from a too tight heating wire sucks, cause it is just as bad as cold fingers. I had two pairs before I fingally got a pair I could ride in more than an hour.
last feb I went and rode the Dragon a 7 hour ride that day and temps were arround 32* when I got home and you need good fitting and good heating gear for those rides. good luck and enjoy.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
