Possible SERT or EFI problem???
Old Oct 21, 2009 | 09:25 PM
CroK's Avatar
CroK
did he say how low it was? that very well could account for lifters starving for oil. just like turning a corner in any vehicle with low oil, the light comes on from lack of lubrication.
And yes, I have to agree... I check oil every chance I get, at least every timeI fill up the gas tank. Ya never know unless you check it.
Old Oct 22, 2009 | 08:29 AM
Tony P's Avatar
Tony P
He didn't say. He did say it was nothing to be concerned about. Maybe I have a valve seal that's not seated properly...
Old Oct 22, 2009 | 09:59 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Pull your plugs see if one or both are real black/wet and sooty. The 05's had a problem with valve guide seals allowing oil past the valve stems into the cylinders, thus "using oil". I will agree with the low oil level and oil starvation to a lifter, the valve was affected and then you sensed a different noise and power shortfall. I would check the oil level a little more often particularly before a long trip and when you get gas, at least when its put away for the night.
Old Oct 22, 2009 | 10:33 AM
Tony P's Avatar
Tony P
He did pull the plugs and they looked normal. From here forward, I will be checking it every 1,000 miles.
Well-Adjusted Outlaw
2014-2024 Touring Models
16
May 10, 2015 01:45 AM
KSRoadKing
Jun 29, 2013 07:39 PM
FXDB
Jul 26, 2010 11:02 PM
moggy
Mar 23, 2007 02:15 PM
batorizer
Jul 14, 2006 10:04 PM
