The safety lock is engaged. Look at the base of the jack handle and there will be a chrome lever that needs to be pulled out and disengaged.
MAKE SURE THE JACK HANDLE IS TURNED ALL THE WAY THE CLOCK-WISE BEFORE DOING IT OR HIS BIKE WILL DROP...
on another note, if he can't work a jack, what is he doing to his bike? nomsayin...
This is correct but as others have said you must "pump" the handle once or twice to raise it off the safety lock, release the lock bar & slowly turn the lever counter clockwise to lower.
You guys could make a mint sellin ring side tickets to your next maintenance project! I'd buy one! Just teasin ya, everyone has a first time with everything.
Well, for what it's worth, I've had two bottles go out on my J&S in the past. So, it's not just the cheap ones that break down. Has it been detemined if this was just a case of operator error?
