Green Locktite...how to remove?
Old Dec 31, 2009 | 08:24 PM
Lindsey141's Avatar
Lindsey141
Default Green Locktite...how to remove?
The back bolt on my sporty's gas tank seems to have green locktite applied to it.
Does anybody know of a way to un-locktite it?
Ive heard that heating it might work but its a painted area so putting a flame to it is not really a option.
Appreciate any help on this.
Old Dec 31, 2009 | 08:31 PM
JW1200's Avatar
JW1200
If worse comes to worse, you should be able to get a jig saw in there and cut the bolt off. Then buy a new $2 nut and bolt....
Old Dec 31, 2009 | 08:36 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Try a hair dryer or heat gun. That should be enough to soften the loc tite.
Old Dec 31, 2009 | 08:40 PM
Eyeball Kid's Avatar
Eyeball Kid
http://www.loctiteproducts.com/quest...p?answerme=125
According to the Loctite site...
Apply heat, and remove.
I've always heard 300° to 400° will do fine.
Old Dec 31, 2009 | 08:44 PM
Lindsey141's Avatar
Lindsey141
yep,...thats probably whats going to happen.....maybe a dremel grinding wheel.
was just wondering if any body had some magic cure.
appreciate the response
Old Dec 31, 2009 | 08:46 PM
JW1200's Avatar
JW1200
The dremel is good!!
Old Dec 31, 2009 | 10:40 PM
krusty1's Avatar
krusty1
I used this stuff on some T45 torx tip bolts that we're put in by some McCo gorillas at the factory....with gobs of white HD locktite. I literally twisted 6 tips like licorice, then I tried this stuff (recommended by tool shop I was purchasing more torx tips....said their mechanics swore by it). Worked for me, after I let it penetrate for about 2 hours, with repeated applications....
http://blasterchemical.com/display.cfm?p=50003&pid=4
Old Dec 31, 2009 | 11:51 PM
CroK's Avatar
CroK
dude, get an impact driver...
http://search.harborfreight.com/cpis...=impact+driver
HAPPY NEW YEAR ALL!!!
Old Jan 1, 2010 | 12:00 AM
SportsterBob's Avatar
SportsterBob
Loctite Green is the softest/mildest of the three....A little heat applied to the fitting is all that is needed.
Old Jan 1, 2010 | 12:15 AM
clicker01's Avatar
clicker01
Dang, I never had a problem wrenching off a locktited fastener.
