For you guys installing rigid sideplates
Old Jul 19, 2006 | 12:14 PM
TOMMAY's Avatar
TOMMAY
Default For you guys installing rigid sideplates
for your sissybar. This will make it a lot easier.
Slot out the rear opening so all you have to do is loosen the rear bolt that holds the turnsig and drop the plate into position without taking that PITA bolt all the way out.
Good Luck
Tom
[IMG]local://upfiles/8936/24F3AF619F0B416B9C17686807348535.jpg[/IMG]
Old Jul 19, 2006 | 12:34 PM
ronster's Avatar
ronster
Default RE: For you guys installing rigid sideplates
sounds like a time saver
Old Jul 19, 2006 | 03:06 PM
SHEP's Avatar
SHEP
I have seen the front bolt hole slotted to the end and the rear bolt slotted towards the bottom. Makes a simple "semi" quick detachable.
Old Jul 19, 2006 | 03:18 PM
TOMMAY's Avatar
TOMMAY
ORIGINAL: SHEP
Thanks,will probably do that too. Didn't think of slottin to front,I was thinkin an L from the bottom which would be a lot more trouble.
Old Jul 19, 2006 | 03:47 PM
hd_sob's Avatar
hd_sob
What tool did you use to do that?
Old Jul 19, 2006 | 04:29 PM
TOMMAY's Avatar
TOMMAY
Just laid it out with a straight edge and a sharpee,then stuck it in the vise between two pieces of wood,started the cut with a 3corner file and finished with a hacksaw. Sprayed some black paint on a qtip and coated the cuts and that was it. Stuff cuts real easy.
Good Luck
Tom
Devildoc0986
Nov 14, 2014 09:50 PM
rocky5
May 3, 2013 12:09 PM
jordanball33
Dec 27, 2008 08:14 AM
Uncle_Timmy
Apr 16, 2007 09:35 PM
Nach
Jan 25, 2007 12:49 PM
