BMW tubeless spoked rims
Old Jan 18, 2010 | 10:32 AM
Marksman's Avatar
Marksman
My buddy has those on his Beemer. Its another one of the things he throws in my face. I gotta admit they look good, and what a great idea. Much easier to detail too.
Came with a plug kit and a way to air it up.
Old Jan 18, 2010 | 12:14 PM
bigskyhd's Avatar
bigskyhd
I know there are spoked wheels for Harley's that will hold a tubeless tire. I've seen them, and although I can't remember exactly who made them, I do know they're out there. Keep looking, you'll find them if that's really what you want. If I were serious about them, I'd make some phone calls to wheel mfgs, to scrub out some details. They're available, I'm sure of it.
Old Jan 18, 2010 | 12:21 PM
frog13's Avatar
frog13
Been runnin' these on my shovelhead since 1991, even rode on them to Alaska and back. Excellent customer service if you have questions.
http://www.americanwire.com/motorcylcle.php
Old Jan 18, 2010 | 12:55 PM
Geoff's Avatar
Geoff
All new BMWs include a tire repair kit with CO2 cartridges as part of the bike's tool kit. R series bikes made in the 70's had a hand pump that attached to the frame under the seat.
Old Jan 18, 2010 | 01:05 PM
Marksman's Avatar
Marksman
Hopefully I never get a flat while out with him.
I'll never hear the end of it!
Old Jan 18, 2010 | 01:08 PM
cornishman's Avatar
cornishman
Here is a thread on BMW tubeless wire wheels, i found it via Google on another forum. Seems there are pros and cons to them, much like anything else.
BMW is the only manufacturer to use spoked tubeless wheels. The design uses a cross-spoke pattern, with the spoke nipple at the hub instead of the rim. The wheels are extremely strong, but need some maintenance. However, they are EXTREMELY difficult to true. The factory builds them on a CNC machine, with a final tune by an expert using very special equipment. Your BMW dealer will not touch these wheels, insisting on replacement, despite the rims being available as a separate part.
There are two people to my knowledge who will build or true one of these wheels:
Tim "Bondo"
Wire Wheels Motorcycles in the USA.
"Woody's Wheel Works"
Woody Witte will also rebuild GS tubeless wheels. US$200.00. 2225 S. Platte River Dr. W., Denver, Colorado 80223, Phone: (303) 936-0232, Fax: (303) 922-7943.
Woody says: "...$200.00 using good parts. When we try to save the customer money by re-using his existing spokes and nipples we run into problems...trying to dismantle the wheel, frozen/rusted grub screws and nipples, spokes that do not readily come out of the rim etc... we know lot's of tricks to minimize the cost, (but) the clock does tick at $60 hour flat rate, and we are constantly trying to find better deals and sources for these applications."
There used to be a wheel builder in the UK doing them, but he eventually gave it up, saying it was better to just replace the wheel.
One of Tim's rebuilt wheels
I have personally had the pleasure of truing one of these wheels. Don't bother. Send it to Tim or Woody. Trust me! (I've built hundreds of conventional wheels, and it normally takes an hour or so. But the BMW tubeless wheel I trued took me three days to get right. Mind you it was in Peru, in a back alley etc... but it was still very tough.)
One of the tricky parts of these wheels is the tiny little "grub" or "set" screws used in the end of the spke nipple to lock the nipple to the spoke. These are almost invisible, and the first time I ran into them I didn't know they were there, and couldn't figure out why I couldn't adjust the spoke!
Eventually I found it, and then began the hunt for a small enough allen screw to loosen it. The R100GS uses a 2.0mm allen wrench. I believe all models use the same one. Check! Make sure you have one in your tool kit.
The spoke nipple is steel, not brass like the old style ones, so are susceptible to rust. Many bikes with these wheels have a problem with the setscrew rusting in, making it almost impossible to get out. Highly recommended to spray a little WD-40 on them once in a while, or a dab of grease.
Here are Tim's instructions on spoke replacement .
"Get the spoke, nipple and grubscrew (setscrew). Put it in until just tight. Ring some of the spokes with a wrench and torque the new one until it sounds like the others. Install the setscrew. DO NOT TRY TO ADJUST ANY OTHER SPOKES or you'll be sending the wheel to me for a big bill. The tubeless wheels don't adjust like any other wheel so please don't try it. Now give the wheel a spin and see how much deflection you have and maybe you'll see why the spoke is gone. Catch a twig on a trail? BTDT
If the rim is within 1/8" not too bad on the rear for stump jumping. If more you've whacked something and it needs to come apart and be relaced. Ring all the spokes with a wrench and listen to how many sing and how many are dead. Older R11GSs with Akront rims were kinda soft in the torque dept and that might have caused the spoke to pop. In that case it may need a rebuild."
For more information and advice contact Bondo at Wire Wheels Motorcycles or Woody, info above.
And if you really want to do it all yourself, Ricardo Kuhn and Jon Jen did a major writeup on the job, in pdf format here.
Oldman - New Iron
Jul 8, 2013 02:59 AM
KAH24DupontChevy
Sep 13, 2010 03:00 PM
Scooter68
Sep 3, 2009 06:02 AM
joeld0803
Jun 8, 2008 02:29 PM
lowleveldriver
Sep 11, 2006 12:53 AM
