Heated gear
Old Jan 18, 2010 | 12:22 PM
Wayne Pilato's Avatar
Wayne Pilato
Unhappy Heated gear
Recently got two HD heated jackets and two sets of HD heated gloves. Along with those I got a (one) HD "Temp controller". This controller consists of a power wire from the battery connection and two output wires, one with a black band at the inlet and one with a white band at the inlet. The controller has a black dial and a grey dial and a yellow light and a red light between them. There is a 15 amp fuse between the battery and the controller input wire. I wired each jacket to a set of gloves, then connected both sets of jacket and gloves to the Temp controller, one to the white coded wire and one to the black coded wire. Went for a ride and within a few minutes the 15 amp fuse burned out. Put in a new fuse and again within a few minutes it burned out.
Question: Does each set of jacket and gloves need to be wired separately to a controller, or is something else wrong?
Help! It's cold here in Jersey and we're getting too old to ride without heat!
Old Jan 18, 2010 | 01:06 PM
skootchnc's Avatar
skootchnc
normally.... you'll want to power one set(person) to one controller, and one harness
You have the Dual controller, which will plug into the corresponding plugs on the jacket, and allow you to control the temps of the jacket, and the gloves independantly
Your passenger, should have their own harness, as well as controller
running two jackets, and two pairs of gloves,on one harness, will over load the fuse.
Old Jan 18, 2010 | 01:20 PM
cHarley's Avatar
cHarley
+1 - separate controllers for each rider/passenger. Gloves on one controller ****, jacket/vest on the other.
Old Jan 19, 2010 | 08:32 PM
bigskyhd's Avatar
bigskyhd
You've got the answer now, you need two controllers for two riders.
MURPHCC1
Dec 14, 2016 09:41 PM
reese
Oct 15, 2010 07:28 PM
firedocs
Dec 28, 2009 09:15 PM
blamecanada
Mar 31, 2009 08:48 PM
lecomte38
Dec 13, 2007 10:24 AM
