ATF Dextron in primary, is synthic better to run in that hole ?
I have a question about Dextron ATF in the primary . is there a benifit to running a synthic Dextron ATF in the primary over regular Dextron ATF?? I run a 1996 FXDWG evo. I have run ATF in the primary for a million years.
If you've got high enough temps in the primary to need syn oil, you've got problems syn oil won't help.
ATF withstands the temps in an automatic transmission, so it's over-qualified for use in the primary.
Bare in mind that the primary acts like a heat sink. In some places with OAT's and idling traffic, engine oil temps can exceed 300F and that, in turn, adds significant heat to the primary.
In those conditions, synthetic ATF in the primary is certainly not "over qualified" by any stretch.
