Sportser problem
Old Mar 2, 2010 | 02:33 PM
steph_fraser's Avatar
steph_fraser
Stage II
Default Sportser problem
Hi all,
I'm new to the forum.
I have just recently bought a 53 plate 2004 1200 sportser custom (my first Harley)
Had a couple of ****les, and just thought this would be a good place to ask people with experience!
First one is twice now my speedo has stopped working whilst riding along the road, and second my engine light came on (same time as the second speedo incident) I stopped riding for a min, then fired the bike back up, and everything was fine again - which makes me think of electral maybe?
I got home tonite, then plugged it into my optimiser, and the voltage was down to 13 volts, and it had been up at 14.1 before i got on the bike. (an hour before)
Does anyone know what the problem could be? Is it linked to the battery? (my lights n stuff were still working when my speedo stopped)
Thanks in advance for any help you can give
cheers
Steph
Old Mar 2, 2010 | 02:45 PM
jimsflh's Avatar
jimsflh
Start by making sure your battery cables are tight (both ends).
Also search this forum for diag codes, the post will have procedure for cheking error codes, and what they mean.
Old Mar 2, 2010 | 03:00 PM
cHarley's Avatar
cHarley
First, I suggest you post this over in the Sportster Section. At the top of that section is a thread labeled "Helpful DIY's" that will tell you how to read the diagnostic codes out of the computer.
Second, what the hell is a "53 plate 2004 1200 sportser custom"?
Oh, and welcome to the fourm........
Old Mar 2, 2010 | 03:41 PM
SPERO56's Avatar
SPERO56
i think this guy is from the UK and the 53 relates to the UK registration plates - can't remember what year this would be for but around 2006 (?). The following year it would change to 54. look something like this GU 53 121YX
Old Mar 2, 2010 | 04:31 PM
RHPAW's Avatar
RHPAW
Check for the obvious, like the tight connections the others have mentiomed. After that, the first thing I would suspect is the solid-state voltage regulator. Make sure it is plugged in, although it is not uncommon for one of that age to give out.
Old Mar 2, 2010 | 04:34 PM
notfried's Avatar
notfried
i had a similar problem on a customer's '06...turned out being a bad wire right behind the headlight,at the neck
Old Mar 2, 2010 | 05:10 PM
jaxbeachbadger's Avatar
jaxbeachbadger
I had my speedo stop working once in the middle of a ride. Turned out my front tire was REAL LOW (leaky valve stem). Once I fixed the tire, no problem. That being said, I don't have any idea why there would be a connection between the two, or if in fact there was....
Old Mar 2, 2010 | 05:28 PM
Thundermug's Avatar
Thundermug
Maybe the speedo stopped because you weren't moving?
C'mon dude, you live around the corner from me....let's ride sometime! We can make it a short ride of only a couple hundred!?!
Old Mar 2, 2010 | 08:29 PM
reddog8145's Avatar
reddog8145
I'd get it checked by a reputable dealer, engine management can be a number of thing's,
For our friends across the pond 53 plate refers to a bike registered between Sept 2003 and March 2004, a bike registered between March 2004 and Sept 2004 would have a plate 04, after Sept of 2004 to March 2005 would have a plate 54, Mad eh !!
Reddog UK
Old Mar 2, 2010 | 08:32 PM
redling36's Avatar
redling36
Negative Battery cable at the battery side. I almost guarantee it!
