Noise
Old Mar 4, 2010 | 03:51 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
How many miles on the bike,did you check all your fluids,trans,primary??
Old Mar 4, 2010 | 04:39 PM
Snarly's Avatar
Snarly
Originally Posted by Shoop
Need to get some advice. I have a 2000 RK. Noticed a loud squeaking noise when I let the clutch out especially when the bike is cold. Goes away as the bike warms up. What is it?
Thanks,
Shoop
Like it has been said, the belt is a good bet. It can sound
like it's coming from every where but there.
Old Mar 4, 2010 | 04:49 PM
Dorkman's Avatar
Dorkman
Should have mentioned that it's coming from the front of the bike.
When the squeak starts, hit the front brake...see if it immediately goes away. If not, hit the rear brake...see if it goes away. If it goes away then its brake squeal. If not, then at least you have eliminated brake squeal. Brakes will normally not squeal when the pads pushed by the piston in the caliper firmly contact the disc, unless a bigger problem like the pads so worn they are metal to metal.
Old Mar 6, 2010 | 12:39 PM
Shoop's Avatar
Shoop
Stage III
Well, I checked the windshield tool bag for a mouse and just found a dead one. I also checked the muffler bearings and they looked ok. But did find that the drive belt needed adjusting which is strange seeing the noise seemed to be coming from the front of the bike. But that's what it was. Good call man!
Shoop
Old Mar 7, 2010 | 08:22 AM
jimsflh's Avatar
jimsflh
Yep, we only found it after tearing apart my primary, and examining the clutch pack and tensioner, putting it back together, test ride, and still there. Put her back on the lift and noticed the belt was all off to the left. Aligned the rear wheel again, and viola, it was gone! Glad you didn't have to tear it apart to find it!
ipaguy
May 29, 2021 09:36 AM
hd_doctor
Jul 28, 2018 03:32 PM
uride2
Aug 29, 2011 09:49 AM
PiedPiper
Sep 4, 2008 06:56 AM
jkoch09ultra
Oct 25, 2006 10:10 AM
