Noise
Old Mar 4, 2010 | 01:43 PM
Shoop's Avatar
Shoop
Stage III
Question Noise
Need to get some advice. I have a 2000 RK. Noticed a loud squeaking noise when I let the clutch out especially when the bike is cold. Goes away as the bike warms up. What is it?
Thanks,
Shoop
Old Mar 4, 2010 | 02:33 PM
RHPAW's Avatar
RHPAW
Mouse in the saddlebag?
Old Mar 4, 2010 | 02:41 PM
jimsflh's Avatar
jimsflh
Thanks,
Shoop
Check your rear wheel alignment, I had that problem, turned out to be my belt up against on side of the pully. (Wish we had noticed before pulling the primary apart, but I swear it sounded like it was coming from there.
Old Mar 4, 2010 | 02:59 PM
Shoop's Avatar
Shoop
Stage III
Should have mentioned that it's coming from the front of the bike.
Old Mar 4, 2010 | 03:10 PM
CroK's Avatar
CroK
Check front brake calipers. If the brake shoes are riding against the disk, they can cause them to squeek/squeel a bit. I'd pull 'em apart and clean them to make sure they are releasing properly. Also check the brake fluid reservoir for sludge and/or dirty colored fluid. If you haven't any idea when the fluid was changed last, it might be a good idea to do that...
Old Mar 4, 2010 | 03:11 PM
frontiercat's Avatar
frontiercat
Drive belt needs adjusting...???
Old Mar 4, 2010 | 03:16 PM
riskyfool's Avatar
riskyfool
Lubricate your clutch cable.
Old Mar 4, 2010 | 03:19 PM
NSCoyote's Avatar
NSCoyote
check your muffler bearings.........
i would check your drive belt first then your brakes
Old Mar 4, 2010 | 03:21 PM
RHPAW's Avatar
RHPAW
Mouse in the windshield bag?
Old Mar 4, 2010 | 03:27 PM
jimsflh's Avatar
jimsflh
So did mine, I thought if it wasn't the primary, I was gonna check the neck bearings. Just for ***** and giggles, check to make sure your belt isn't riding off to one side.
